Originally posted by jonohake28 Hello,
What portable studio strobes do you use with your 645z? Which triggers will work? I can't seem to find anything that would work with high speed sync, but can you suggest which triggers I would need with the following strobes - I could shoot with an ND grad in the day to get a large fstop and still use flash instead of worrying about hi sync if it comes to it.
I have been looking at the following and can't really figure out which would work? I'm only really interested in manual operation
Elinchrom ELB400
Phottix Indra500
Godox
Profoto B1 - this one I have decided against because of all the weight being in the head.
Can anyone chip in which they are using and which triggers would be needed and recommended?
I use two battery powered portable strobes, the Indra 500 and Adorama's Flashpoint RL-600B. I use primarily Pocket Wizard Plus III's to trigger both strobes and they work well. I also use the PW's to fire my Bowens and Profoto studio strobes. The benefit to me using the PW's is the built in receiver for my studio strobes and my light meter is PW enabled. So measuring in the field and studio is a breeze. I have to admit I really like the Flashpoint unit, portable, good price and the trigger that comes with the unit works just great with the 645z, and you can adjust the power levels remotely. Adorama frequently has deals on Flashpoint and I think there is one going on right now.
I am not all that interested in TTL flash units - but would love to be able to fire the strobes at shutter speeds greater than 1/125th and may take a look at the Acon trigger with the Pentax firmware upgrade, but $$'s and the fact I picked up a 135 LS for less than the Acon triggers is holding me back
