07-14-2016, 08:41 AM   #1
shake reduction with the 28-45
Hi Guys,
just got this monster here to test and the manual says, that the SR may not work with closeups...
took a couple of portraits with closeups yesterday and seems that SR did not do it's job below 1/50. they were shot with 45mm at about half a metre.
I am not sure what's happening there. So I don't know if it's the distance or just how far down the SR is effective.
what is your take on this?
cheers
Stephan
sorry, can't post pics...
07-15-2016, 02:46 AM   #2
It could be for optical reasons that the SR disables itself at close focus distances. That's just my hunch.
07-15-2016, 03:53 AM   #3
Kolor-Pikker's Avatar
QuoteOriginally posted by zobeleye Quote
Hi Guys,
cheers
Stephan
This simply seems to be the nature of shake reduction at close-focus distances, just look at the footnotes for -any- stabilized macro lens, and everywhere it will say that IS/OS/VR will not work at macro distances. Same with our own 90mm f/2.8, it's rated for only 2.5 stops of effective shake reduction, and even then only at "normal" distances.
I reckon that optical stabilization in general is only effective starting from 1 meter or so with most lenses, and quickly drops off below that. 1/50th is still not bad since I normally keep my shutter at 2xFL or more for critical sharpness on the 645Z.
07-15-2016, 03:55 AM   #4
I've just tried mine at 45mm and around 50cm distance and can see some correction/improvement.
I tested it (not very scientifically) by using Liveview at arms length and focusing on an LCD monitor and there's certainly more moire "dancing" with SR off.
I have a Canon setup with the 100mm macro and the effectiveness of the image stabilisation (4 stops claimed) dimishes very rapidly to zero as the subject distance decreases.
Bob
07-15-2016, 04:37 AM - 1 Like   #5
Fogel70's Avatar
The SR in the lens only compensates for pitch/yaw camera shake, which affect all images regardless of focus distance, but at closeup it's the X/Y camera shake that dominates as it increases with the magnification of the shot.
07-15-2016, 10:42 AM   #6
AAH...
very interesting read, guys.
thanks for your feedback.
I have now completed a series of tests in daylight and can safely conclude that 28-45's SR works up until 1/25, then stops working at 1/20. that's at 45mm.
for the other thing with the distance, again at 45mm, I can say that it still works brillantly at about 45 cm, so no problem there.
I assume it was something with the switch, cause I did not switch it on/off/on when I got it , since it was already engaged. and I did only today notice that it shows a litlle icon in the finder when engaged.
so all good apparently...
cheers
Z
645d, 645z, camera, medium format, sr
No Shake Reduction with Samyang madphys Pentax DSLR Discussion 11 04-15-2015 11:24 AM
Inability to set shake reduction with 1.02 firmware HETREL Troubleshooting and Beginner Help 2 03-13-2015 12:14 AM
Using Shake reduction with a monopod MikeD General Photography 6 02-01-2015 06:35 PM
Shake reduction use with Hi continuous drive mode dfp771 Pentax K-30 & K-50 5 11-24-2014 08:44 PM
whats the deal with the Shake reduction lordson Pentax DSLR Discussion 19 11-13-2007 05:51 AM
All times are GMT -7. The time now is 06:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
