08-29-2016, 05:34 PM   #1
645 C/S switch stuck.
Hey everybody,
I've recently picked up a 645 film body, and upon inspection it seems that the C/S switch won't budge one bit. Keep in mind I don't have a lens or a film back for it. The shutter does fire, and all seems well. I was just curious if this was a function that wasn't available until I insert a film back, or if something was wrong with that function of the camera (not that I'm going to be throwing away frames in continuous anyways.) Any help would be greatly appreciated. :-)
08-29-2016, 08:18 PM   #2
pjv
pjv's Avatar
QuoteOriginally posted by nikonshooter32 Quote
Hi Shaun. Apologies for not being able to answer your question, but in researching it, I came across this. I am assuming that you already have a manual, but in case you have not..........................................................
http://jafaphotography.com/downloads/645.pdf
08-29-2016, 09:58 PM   #3
Alex645's Avatar
Your C/S switch should rotate either direction regardless if there is a lens or film back on the camera. It alternates from Continuous to Single back to Continuous then again Single. Itʻs a dial with C on either end and then S 90 degrees from either C. Sounds like itʻs seized up and needs a little "help".
08-30-2016, 01:04 PM   #4
You're absolutely right, it just needed a little "help" . With a little persuasion I managed to get it free. All is right with the world.
645d, 645z, c/s switch, camera, film, function, medium format, switch
645 C/S switch IgorZ Pentax Medium Format 6 06-23-2017 02:14 PM
Why is the Auto/Man diaphragm clutch stuck on my S-M-C Takumar lens? (there's a pin!) Adam Maintenance and Repair Articles 10 11-01-2013 10:42 PM
s and c mode on 645 ponggo Pentax Medium Format 14 01-20-2013 01:01 AM
KX stuck in autofocus, but switch is stuck in MF icywarm Troubleshooting and Beginner Help 4 08-07-2012 07:21 AM
Help! Autofocus switch stuck on AF.S and will not autofocus! pauldiebel Pentax DSLR Discussion 3 09-19-2009 08:59 PM
All times are GMT -7. The time now is 04:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
