Originally posted by Kolor-Pikker 1. It's likely an artificial limit, the Leica S 007 goes to 12,500 and doesn't look any worse than the the 645Z, which I wouldn't shoot any higher as from that point on it looks too bad to be worth it. The sensor is ISO invariant anyway, so it's better to push in post than risk losing highlights that you can't bring back.
2. The dials all have automatic positions, which means their functionality can be handed off to the front/back dials, and set arbitrarily. The lack of immediate control for all three settings shouldn't be missed as most people often just shoot at one relevant ISO or have auto-ISO active and only set the aperture and shutter speed. You can just see on the photos that the dial setup is the same as on the Z.
3. Distance scales on modern AF lenses with short focus throw lack the accuracy on high-resolution sensors that's needed for them to be relevant, as you say, it's a much better plan to do what Phase have on the XF and embed distance/DoF data into the top panel based on which lens you have attached, it's a far more elegant and modern solution.
1. Personally, I'd rather decide where the upper ISO limit resides (having grown up with high ISO film, I'm a lot more tolerant of grain than kids these days). Although it may be true about the highlight issue, some kinds of low-light photography have flat lighting
2. The dial setup seems very different from the 645Z (the 645Z lacks labeled dedicated dials for ISO and shutter speed) while Fuji seems to lack a mode dial (presumably, it's on the back some place). What would frustrate me is having to use the labeled control dials one way for some parts of the shutter & ISO range but then use different dials for extended parts of the shutter and ISO range. Does the Fuji have back dial(s)?
3. Yes, one of the design limits of many AF lenses is the short focus throw. Presumably, the Fuji lenses have a fly-by-wire system for manual focus so one has better fine control. But on hikes, I tend to mount a new lens and prefocus it a likely working distance with the camera off.
---------- Post added 09-20-16 at 08:30 AM ----------
Originally posted by Apet-Sure When you add an extension tube between camera and lens, you 'lose' light, right? So if you move a lens closer to the sensor by removing the mirror box, does that mean you 'gain' light? Is it like the equivalent of having a faster lens without the need of a wider aperture?
Yes and no.
If you add an extension tube, pushing the lens beyond it's usual distance, the image circle grows larger and the light per unit area drops. But it's possible to design lenses that have a lot of air between the last element and the sensor that don't lose light.
That said, the ability to have a lens with elements that are near the sensor (with a big enough mount diameter) provides lens designers with more freedom to create a compact lens, correct aberrations, and to direct the light on to the sensor. It mostly helps with the design of shorter focal length lenses.
