10-05-2016, 03:30 PM   #1
How to Set up Camera Profiles on 645Z
This might sound stupid BUT I have NO idea how to set up Camera Profiles with my 645Z. I am using LR 6. I read something on Huelight Camera profiles.
I am not sure where to even start to do this. Any Help Is Appreciated. Also, Which is the Best Profile to use for my 645Z?
I shoot mainly Portraits and Family groups and some Landscape. Thank you in advance.
10-05-2016, 04:45 PM   #2
Not an article- moved
10-05-2016, 05:51 PM   #3
Hi Adam I wasn't sure where to post it. Can you tell me where it was moved to. Thanks
10-05-2016, 06:11 PM   #4
I'd recommend trying Anders Torger's 645Z profiles, as these provide really good colour rendition on raw files.
See this thread for more details:
https://www.pentaxforums.com/forums/48-pentax-medium-format/304845-new-camera-profile-645z.html
10-06-2016, 12:42 AM   #5
For a recent version of Windows, you put the profiles in the following directory;
<Your username> AppData> Roaming>Adobe>CameraRaw>CameraProfiles .........you'll see many other profiles (.dcp files) in this directory.
Older versions of Windows and Mac's will be different.
I use the Huelight versions and they seem to be an improvement over the Adobe standard.
Bob
10-06-2016, 01:33 AM   #6
Kolor-Pikker's Avatar
QuoteOriginally posted by paulster Quote
It's hard to find the latest ones (v0.10.4) unless you know the address:
http://torger.dyndns.org/dcamprof-v0104-pentax-645z-neutral.dcp
http://torger.dyndns.org/dcamprof-v0104-pentax-645z-neutral-plus.dcp
IIRC top one is done strictly based off an X-rite color checker, plus version is manually tweaked to look better in some aspects. While I don't find them to be particularly accurate and require extra tweaking in post, they do indeed have nice colors.
10-06-2016, 03:39 AM   #7
QuoteOriginally posted by rollsman4 Quote
Does not sound stupid at all so don't let it stop you asking for opinion, you will probably be helping others that have not asked the question yet .
Important to remember that image colour is pretty subjective and you may prefer generally warmer or cooler colours than others, your memory of the recorded scene may well be different to the actual scene at the time of shooting and/or you may desire quite a large departure from the scene reality. Generally camera profiles are used to try and get a more accurate view to present when loaded into your editor of choice, taking into account the lighting conditions etc. and you would normally expect to do at least a little post processing to get the image the way you visualised at the time of capture.
So applying a camera profile may or may not help in getting to where you want the final image to be.
If you have fallen in love with the image on the back of the LCD then you may either try and replicate a camera profile using either X -Rite or Adobe DNG editor or you may consider just simply making a LR develop presets (or several for different purposes).
If you do want to try this route I would suggest that you start off with a pristine raw straight from camera into LR and make adjustments to this image then save as preset. If you want to match the look of the LCD with a camera preset then save image as raw and JPEG. Display both on screen and edit the raw to match the JPEG.
A quick comparison of image profiles applied to 645 image in LR showing Embedded, Adobe Standard and Anders Torger's Neutral and Neutral + versions.
10-06-2016, 04:33 AM   #8
Thank you Tony. I appreciate the explanation and the comparisons. I will check into this and see what works for me. Thanks again, Dennis
645z, camera, camera profiles, profiles
How to magnify manual focusing on 645z? the_ether Pentax Medium Format 6 03-08-2015 04:20 PM
645Z and wireless flash set up for macro gary alan Pentax Medium Format 6 01-31-2015 02:41 PM
How to set up sooting into RAW only Libor Pentax K-3 7 09-29-2014 04:45 AM
How I set up shutter speed on my PENTAX spotmatic to sync w svn.ictus Pentax Film SLR Discussion 6 09-09-2011 07:51 AM
How do you set up trap focusing on K10D? meremonkey Pentax DSLR Discussion 2 07-30-2007 12:56 PM
All times are GMT -7. The time now is 08:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
