10-10-2016, 01:51 AM   #1
645Z Timer Remote
I am trying to find a wired remote for the 645Z that supports a timer - for long exposures, but am struggling to find one that supports the 645Z.
Can anyone point me at a remote that works with the 645Z ?
Thanks
Phil
10-10-2016, 01:59 AM   #2
Digitiser of Film
BigMackCam's Avatar
A quick Google search for "timer remote 645Z" brought results up for several different models including the Yongnuo MC-36R and JJC TM-C
10-10-2016, 02:01 AM   #3
Closed Account
Mike just beat me !!!
Yongnuo MC-36b C1 Timer Control Shutter Remote Cord For Pentax 645Z 645D
10-10-2016, 04:24 AM   #4
TriggerTrap also works, you need cable, app and smart phone.
10-10-2016, 10:55 AM   #5
Thanks guys - a lot of these (in the UK) don't state 645Z, just Pentax and they show some with USB connection and some with a different connections; all very confusing :-)
Anyone know if this one works - Neewer LCD Timer Shutter Release Remote Control Cord RS-60E3
10-10-2016, 11:22 AM   #6
The Neewer should work fine. Pentax and Canon use the common 2.5 mm stereo jack plug with the same pin out connections
10-10-2016, 01:13 PM   #7
Thanks Tony; just ordered one. Expecting some long exposure work next week as I am doing some coastal shooting in North West Scotland and I am fed up with counting the seconds :-)
Phil
10-12-2016, 09:09 AM   #8
Maybe I am missing the trick here :-)
I got a JJC TM-C and I set it for a Bulb exposure of 10 seconds with a number of shots of one; camera set to bulb with Mirror Up turned off. Press Start and it starts the exposure and then counts down. When it gets to zero nothing happens and the camera stays open. If I set it to 2 shots, press start - starts the exposure, counts down and closes the exposure when it fires the second shot and then counts down again to zero.
Now either I am missing how this is suppose to work, or have a setting set wrong somewhere.
I would have thought on one shot, it would open the shutter, count down and then close the shutter all itself once I did the initial press of start.
Appreciate all comments telling me what I am doing wrong :-)
Thanks
Phil
10-12-2016, 10:04 AM   #9
Sorry if this is too basic, Phil, but are you pressing the "Set" button before starting the sequence? I have the wireless version and presumably it has the same MO.
Bob
10-12-2016, 10:17 AM   #10
No answer is too basic (not the way I am feeling today )
Yes, it is all set and set pressed. As it works for 2 shots, but not for one - it seems to not be getting the "close" signal sent to the camera; hence the 2nd open is going in as a close.
Phil
10-12-2016, 12:07 PM   #11
I'll give mine a try later.....(bought for my Canon gear but I do have a cable suitable for the 645Z too).
Bob
10-12-2016, 12:18 PM   #12
Thanks Bob, appreciate any help
10-12-2016, 02:52 PM   #13
I've just given it a try, Phil, and it works as expected. The wireless version also has to option to plug the cable directly into the transmitter (which I did) and I tried a single exposure and a 3 shot program with both completing normally....as it performs with my Canon gear too.
Mine is the JJC WT-868 for what it's worth.
Bob
10-12-2016, 09:38 PM   #14
Thanks Bob
Something is stopping this working and I don't think it is the remote. Just tried a different remote (Neewer one) and the same happens; the shutter is opened but not closed at the end of the timer. I am thinking something is stopping the close signal being processed, but cant think what it is (I am assuming a setting on the 645Z)
Phil
10-13-2016, 12:28 AM   #15
A long shot (based on my perception of your perception of what's occurring)....how about "Slow Shutter Speed Noise Reduction"? Your user guide may not accurately reflect the camera's menu as I believe that there was a firmware change addressing the options for this feature.
Bob
645d, 645z, 645z timer, camera, medium format, timer
K3ii remote/intevelometer-timer plug input.... SKYGZR Pentax K-3 & K-3 II 2 09-28-2016 08:20 PM
645Z - turn off the self-timer? RobertM Troubleshooting and Beginner Help 3 02-11-2016 02:06 PM
Interval Composite with remote or timer? PenTex Pentax K-3 & K-3 II 17 03-30-2015 02:59 PM
Wireless remote timer recommendation? stuskier Pentax Camera and Field Accessories 3 01-20-2011 08:03 PM
Digital Remote Timer eccs19 Troubleshooting and Beginner Help 3 12-06-2010 04:17 PM
All times are GMT -7. The time now is 02:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
