10-10-2016, 04:07 AM   #1
Pentax K Lenses on 67 Mount
Hi folks,
i'm not sure either if it's the right section and a question with sense, i was looking for an adapter to use pentax K lenses on 67 mount, i know that using a lens made for a smaller sensor can bring some issues (corner softness and aberrations, sharpness etc) i would like to know if is there anything available
thanks in advance
10-10-2016, 04:29 AM   #2
I don't think there is. The 6x7 format is more than twice FF size, so K-mount lenses wouldn't make much sense.
10-10-2016, 05:09 AM   #3
I think you have to get that adapter specially made for you. Be aware that the focal flange distance is very different so you wouldn't be able to focus to infinity. Probably only in the macro range. When focusing that close the image circle will probably be significantly larger then normal, but not necessarily as big as 67. Vignetting would probably be very significant.
To sum it up, I think its a bad idea unless the purpose only are proof of concept.
10-10-2016, 09:19 AM   #4
gofour3's Avatar
The only way you can use a 35mm format lens on a 6x7 camera is reversed. Pentax made a 6x7 mount adapter with a 49mm filter thread just for that purpose.
I have used my SuperTakumar 28/3.5 reversed on a 6x7 body for Macro work and it worked very well with around 5x magnification achieved. (With the 6x7 helicoid.extension tube)
Phil.
645d, 645z, camera, lenses, medium format, pentax, pentax k lenses
K Mount lenses on Fuji x Mount? Uncle Pete Non-Pentax Cameras: Canon, Nikon, etc. 5 09-12-2016 08:49 AM
Adapted Lenses on the Pentax K mount anu l Pentax SLR Lens Discussion 13 01-06-2016 11:08 AM
Leica lenses on a Pentax K mount camera? kshapero Pentax SLR Lens Discussion 4 07-16-2014 03:05 PM
67 lenses and K-mount b0bg Pentax SLR Lens Discussion 2 01-18-2010 10:20 PM
pentax 67 lens on k mount? roentarre Pentax SLR Lens Discussion 11 12-07-2006 03:00 PM
All times are GMT -7. The time now is 01:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
