11-05-2016, 04:59 AM   #1
6x7 film advance issue
Hello, I have an issue with a newly aquired 6x7. Sometimes when winding the film advance lever the mirror will raise fully. When pressed, the shutter will release and mirror returns to rest position. The exposure of the film is not effected. The MLU works as designed when the camera winds on properly, ie. when the mirror is not pulled up by the advancing lever. With lens removed you can see the mirror move up GRADUALLY as the advance lever is wound on. It's an intermittant problem but I've noticed the lever which operates the aperture (in the mirror box) is a little sluggish and if not fully up after shutter activation, the mirror raises with the next wind on, anybody see this before???
11-06-2016, 08:23 PM   #2
Silent Street's Avatar
That is not right. The film wind-on lever has nothing to do with raising or lowering the mirror, only pulling the film across the film gate after the exposure. Mirror up/down movement occurs in sync with the exposure at the shutter: the sequence is thusly: press the shutter, mirror rises, shutter opens/closes, mirror returns to viewing position. All this is makes quite a din. The MLU lever should raise the mirror immediately it is tripped. That done, you then trip the shutter, which will process as per the line above (shutter opens/closes, mirror returns...).
I don't think it is a battery-related problem, but something is not quite right under the skin. You could try a fresh battery, but if this odd behaviour of the film wind-on persists, it's time to take the beastie to the Doctor.
11-07-2016, 05:03 AM   #3
QuoteOriginally posted by Silent Street Quote
Thanks again for your reply. A bit more research and I found that this was a problem seen in M Series, K Series, Spotmatic, SL,P Series, Program A Super A cameras, no reference to 6x7 or 67 however. The camera hasn't operated for many years and is now with a retired camera service technician for some cleaning and light lubrication. I've a feeling the problem might be a latch or cam being a little lazy from lack of use and lubrication. I'll update when I get it back.
11-07-2016, 08:54 AM   #4
Otis Memorial Pentaxian
QuoteOriginally posted by irishbeachboy Quote
If the described problem (mirror lift on wind) is common for M, K, P, A, and Spotmatic series, it is news to users on this forum.* I have seen this happen, however, when the wind/cock/release sequence is out of wack on various brands of SLR cameras. If your technician is competent, the problem will be addressed as part of the CLA. Enjoy your 6x7!
* No sense reinforcing a new Internet "truth" that almost all manual focus Pentax SLRs over a 30 year span are particularly vulnerable to a mirror interlock problem.
02-25-2019, 10:16 PM   #5
murrelet's Avatar
Reviving this old thread... @irishbeachboy, did you ever get the mirror up on film advance issue resolved? A friend is having this same problem with his 67.
03-04-2019, 03:30 PM   #6
QuoteOriginally posted by murrelet Quote
@ murrelet, It needed a complete overhaul, there was corrosion inside the camera, I got it back in working order thanks to parts from other cameras! That's not to say your friend's camera needs an overhaul, best let an expert have a look.
645d, 645z, 6x7, 6x7 film advance, 6x7 mirror, 6x7 shutter, advance, camera, film, issue, lever, medium format, mirror, shutter
Pentax 6x7 frame counter will not advance tambrico Pentax Medium Format 5 08-04-2016 04:59 PM
Pentax 6x7 film advance not working Steve H Troubleshooting and Beginner Help 4 07-31-2016 12:50 PM
645N film advance KDINDC Pentax Medium Format 3 06-16-2016 05:48 AM
Pentax P5 film film advance jammed Nelson_Rios Pentax Film SLR Discussion 5 02-09-2016 09:14 PM
K1000 - film advance lever clicking, film wont budge. hiddenvibe Pentax Film SLR Discussion 6 01-20-2015 04:52 PM
All times are GMT -7. The time now is 09:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
