02-06-2017, 11:41 PM   #1
TDvN57's Avatar
Question about 600mm A-star lens with 645z
Would appreciate some input if someone has used the 600mm A star lens on the 645z body. Any opinion or suggestions would be welcome. I am considering to buy one to replace my very heavy 600mm 67 lens.
02-07-2017, 12:08 AM   #2
Have you seen the user reviews?
SMC Pentax-A* 645 600mm F5.6 ED [IF] Reviews - 645 Telephoto Primes - Pentax Lens Reviews & Lens Database
02-07-2017, 04:16 AM   #3
TDvN57's Avatar
Yes thanks, I saw those were done a while ago. I was hoping there is someone actively using the lens on a 645z that can give current information.
02-07-2017, 06:37 AM - 1 Like   #4
I wrote one of the reviews and my thoughts remain the same. The lens is even better with a 645Z since the high ISO capabilities allow higher shutter speeds. Recent example attached.
PENTAX 645Z  Photo
02-07-2017, 08:51 AM   #5
bobbotron's Avatar
QuoteOriginally posted by Thomas Quote
Hey Thomas, I'm very curious. At some point could you take some photos near minimum focal distance with this lens and the 645Z? This is a pretty neat lens, I'm curious to see what the output is like, will likely never own one myself.
02-07-2017, 09:28 AM   #6
TDvN57's Avatar
Thomas, much appreciated. I have a few questions:
1. How much of a problem is CA, especially towards the edges.
2. I am thinking of combining it with the 1.4x converter. Any thoughts on this?
I also have a 2x converter, but are not impressed with the results on any of my lenses.
3. At present I use my 400mm lens with the 1.4x.converter to get me to 600, but at the expense of light. CA is not much of an issue in this configuration.
4. I would be using it mostly as handheld, which is a problem for a long lens, I know, any thoughts or advice on this?
02-07-2017, 10:17 AM   #7
QuoteOriginally posted by bobbotron Quote
Below is about close focus limit. Flowers about 3 in/8cm in diameter; not sure of the distance. Wide open BTW
---------- Post added 02-07-2017 at 03:46 PM ----------
QuoteOriginally posted by TDvN57 Quote
can get the most from th
Almost no CA anywhere; the lens is highly corrected with 12 elements.
Works well with the 1.4x; sold my 2x.
I don't use this handheld very often and even then rest the barrel on something. I use the 400mm handheld frequently, but not the 600. Keep in mind this is a MF lens, so the hand needed to turn the focus ring also must support the lens barrel. My experience is that is very difficult to achieve the quality this lens is capable of using it handheld.
Also, shutter shake is a real issue at slower shutter speeds.
---------- Post added 02-07-2017 at 03:55 PM ----------
PENTAX 645D  Photo
02-07-2017, 10:56 AM   #8
bobbotron's Avatar
Thanks for indulging my curiosity! That is very nice.
Almost no CA anywhere; with 12 elements it's a very well corrected lens.
1.4x works well; I sold my 2x.
I rarely use it handheld and when I do, I try to rest the barrel on something; it's an awkward lens to hold and focus. I use the 400mm handheld frequently, but not the 600.
02-07-2017, 01:53 PM   #9
TDvN57's Avatar
Thank you, much appreciated.
02-09-2017, 01:38 AM   #10
672
just to be clear, your 67 400mm edif lens plus 1.4 converter is only one pound heavier than the 645 600mm.
---------- Post added 02-09-17 at 12:45 AM ----------
i use the 67 400mm edif lens myself. sometimes with converter. its and amazing combo.
you mention that you would put a converter on the 645 600. in that case don't rule out the 67 800mm.......
02-09-2017, 07:22 PM   #11
TDvN57's Avatar
QuoteOriginally posted by 672 Quote
I currently have the 67 600mm with converter, but it weighs 6.5kg, excluding the camera. I find handheld impossible. Looking to switch to the 645 600mm instead.
04-24-2017, 06:47 PM   #12
Just curious, A-star 600mm compare to Mamiya 500/4.5 apo, which one would have better optical quality? I would like to see 100% crop from this lens with 645z.
05-11-2017, 07:09 PM - 1 Like   #13
TDvN57's Avatar
One of the early test shots with my new 600mm A* lens. Taken through a dirty hotel room window on the 30th floor, across the Hong Kong harbour. At first I could not see the building by eye, it was just too dark. I guessed the focus, set a 30 second long exposure and fired away. The picture shows the original full picture and superimposed upon it is a +/- 150% crop of an apartment building, about 4km away (I measured on Google Maps the next day).
At first the results look like a bad out of focus shot, however considering that the building is 4km away, it is a 30 second exposure and through a really dirty window, I am impressed with the outcome. Ignoring the potential tripod shake and movements, at that distance the structural movement of the building I am in will contribute to the "shake" effect seen in the picture.
Now I need to learn how to work this baby and then take it out for some real pictures.
PENTAX 645Z  Photo
05-12-2017, 08:32 AM   #14
Looks good. Congrats!
05-12-2017, 01:40 PM   #15
QuoteOriginally posted by wilco23 Quote
Just curious, A-star 600mm compare to Mamiya 500/4.5 apo, which on would have better optical quality?
Both of these lenses are modern designs using low dispersion glass. They are both probably corrected for 3 colors and have very low tertiary spectrum and low spherochromatism. I have not compared the two but it is safe to say that they have similar performance.
1.4x, 2x, 400mm, 600mm, 600mm a-star lens, 645 600mm lens, 645d, 645z, barrel, camera, converter, distance, edif, focus, issue, lens, light, medium format, mf zoom lens, question about 600mm, shutter, thomas
Questions about a SMC Pentax FA 250-600mm f5.6 ED[IF] lens Weevil Pentax SLR Lens Discussion 28 08-24-2019 11:18 AM
Question about depth of field when shooting with a longer lens highermonkey Troubleshooting and Beginner Help 6 08-04-2016 09:26 AM
Question about A lens heraldaz Pentax SLR Lens Discussion 6 08-23-2015 01:55 AM
Question on a tou / five star lens jenniferd Pentax SLR Lens Discussion 3 12-24-2012 03:34 PM
Question About Using an M42 Lens with a ZX-M Body zx-m Pentax SLR Lens Discussion 6 06-05-2008 03:38 AM
All times are GMT -7. The time now is 06:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
