Originally posted by thomasfallon Tried that. The card won't format in the camera. I read comments on here about the Flucard such as "The Flucard is joke.: That did not inspire me.
Card won't format? Assuming it was that way out of the box, return it for full credit as defective. If the factory format was initially good and you had used it on a personal computer before trying your camera, it may be there is corruption that may be remedied by formatting using the utility from the SD Association web site.*
SD Card Formatter - SD Association
Use the option for Full (Overwrite) and reformat using the camera before taking pictures.
As for wireless to an iPad...your options are the same today as when you purchased your camera...Eye Fi or Flucard, chose your poison.
* This is the standard recommendation when people get the "Memory Card Error". The cause is usually either a format attempt using the computer OS or other-than-clean unmount/eject before removing the card from a reader.
