Originally posted by Bob L profiles were moving the WB around
Hello Bob,
that's right. Also the Huelight profiles and other profiles, which I also use, move in most cases the WB.
Greeting Gerd
---------- Post added 03-05-17 at 03:17 AM ----------
Originally posted by paulster So I use Anders Torger's DCamProf profiles and I found the following when I tried switching profile on the same image:
Embedded 6100+23
Adobe Std 6400+16
Camera Natural 6400+16
DCamProf 6400+16
It seems that all are interpreting the file as 6400+16 with the exception of Embedded. And none of them are close to the correct value metered from the grey card.
Hello Paulster,
the standard Adobe profile or the embedded profile, but if the camera is set to neutral, the WB in Lightroom may not be allowed to move this.
The manufacturer production tools such as Capture NX for Nikon or also Digital Camera Utility for Pentax do not do that either. In these tools exactly the WB is displayed which I have adjusted in the camera - on the Kelvin exactly.
What is conspicuous is: If I set fixed WB profiles in the camera such as Daylight, Cloudy etc .. then the deviations in LR is not so strong. If I adjust manual values in kelvin - and I do almost always - then the deviations in LR are in part considerable.
Of course this is not a broken leg, because you can always influence the WB - in the RAW file - in 100%. But if Adobe writes to the controller a value - like Kelvin - and that's not true. Then they should write to the controller only "for fun".
Alternatively, a manual entry would be appropriate why and how the WB value in Adobe products is composed. Then all can handle it.
Greeting Gerd
---------- Post added 03-05-17 at 03:34 AM ----------
Supplement - I had just forgotten on the subject WB in LR:
For example, if the kelvin value is "as shoot" equal to 5400K - then LR does not sync 5400K between different photos but only the value "as shoot". You have to change the value to 5401K and then the kelvin value and not the value "as shoot" will be synchronized.
In LR, unfortunately, there are many inconsistencies on WB.
Greeting Gerd
