Originally posted by pumpkinandpeach When i flip the switch for the light meter it goes straight up over the + sign and does not come down to resting position until I turn the switch to off or the 15 secs are over. I can change aperture and shutter speed or go into a darker room or lighter room and it still goes straight up out of range every time. Any ideas why? I did take the TTL top off and put it back on once without taking the lens off. I don't know if this would cause the light meter to act this way. The meter stays up towards the top when off.
thanks,
tyler
Is the body still equipped with a chain properly connected to the aperture indexing ring? To check... remove the lens and the finder... look at the long slot towards the front of the bay... and notice the dark index tab towards 12 o'clock of the mount for the lens. When you slide the indexing tab of the mount, the index shuttle and chain should move and be observable in the long slot. If the tab on the TTL is not seated correctly, the meter may be stuck in bypass mode.
