Originally posted by pathdoc Any way you slice it, it's going to put a big hole in your wallet!
What's the crop factor on these things, for FOV comparison? That Pentax 75/2.8 looks like a steal compared to the others; are we sure there shouldn't be a 1 in front of that 696?
It's sort of scary that the 645Z isn't even the bargain price alternative it used to be. The only advantage it has (to the extent that it is one) is that expanded lens lineup.
crop factor is .79x for all three cameras.
fa 75 2.8 being so cheap could be due to the flange distance, hence easier to produce the 75mm lens for pentax. and that it could be the standard lens bundle when you buy 645 cameras even back in the film era??
yeah, when you look at the modern da lens selections, they're just outrageously expensive no matter where you look lol.
Originally posted by texandrews The comparison requires only consideration of new lens prices, and only if you only select particular lenses. In the case of the Pentax 25, it's such a rare bird that you are probably going to pay nearly that price even if you find one used, or else you get very lucky. The 90 will also be pricey used, but you may have an easier time getting lucky. The 55 is much more easily gotten used---that's how I have it---at half or less than half the price you use for new.
But then there's the real possibility of going with the excellent 120 in Pentax, and I got mine for less than $300.00. And so to this point: with Pentax, you do have some other options, not only because the lens selection is richer, but also because so much is available used.
That is not the case with the Fuji at all. That the Fuji could accept legacy glass through adapters mitigates that a little, but early reports are that many don't adapt well. I am not sure how the Hassy adapts older lenses.
So, I think it is both not so simple here, and also most likely cheaper (possibly much cheaper) with Pentax if you are willing to wiggle bit.
its true, but you kinda have to compare orange with orange, and compare only the latest and most up to date lens selection from each manufacturer.
i think alot people when deciding to get the 645z will consider the fa lens, and i personally is currently on this route for fa 45-85 fa 80-160.
but when you look at the modern 25 28-45 90, it just amazes how much these lens cost.
ps, i've not used any of those lens, so idk how they perform against the others, maybe they're just that much better?
