Don't shoot the camera without a film in it. Load a film, and it should go back to normal (I did the same thing when I first got my original 645 - scared the hell out of me!)
\edit I've since acquired a plate you can insert instead of a film, and be able to trigger the shutter without a film loaded. I've also had another 645 body that needed help getting the shutter down because it hadn't been used in a decade before I bought it. With a film loaded, it should come down (when you wind those first frames on - if no film is wound on, the shutter will not return). If it doesn't, gently pulling it back down is worth trying (but only with a film loaded!!!!). That body stuck twice, but has been fine ever since then!
