Originally posted by BigMackCam ...
1) Start off with the camera's own dust removal function, running it a couple of times in succession with the lens off and the camera pointing down
2) Next, use a good quality bulb blower - again, if you can point the camera down while doing this, it's better. You need to get the nozzle of the blower reasonably close to the sensor, but be careful not to touch it
3) If spots remain, use the Pentax O-ICK1 gel-stick to lift off any debris, cleaning the gel on the sticky paper provided after each lift-off (the O-ICK1 is superb - works brilliantly)
4) Finally, if the above still hasn't got rid of everything, wet clean using good quality DSLR sensor swabs and "Eclipse" or other good quality, high purity cleaning fluid
5) In case the wet cleaning has left behind any fibres (it shouldn't, if good quality swabs were used), return to step 1
It's important to do the steps in this order to minimise the small but present risk of damage. After each step, check to see if the dust bunnies have gone from your images. When they have, stop.
Re DSLR sensor swabs, I have no specific recommendations, except to say that it's worth buying good quality branded types. Don't go for the super-cheap Chinese swabs on eBay... you have no idea whether they were manufactured in a clean environment, and the material may not be lint-free.
I use the same process above for my Hasselblad HV and Sony A7II, but with the Sony-safe Eyelead gel stick instead. No problems there, either.
I'm not a fan of the static brushes and Arctic Butterfly... they work to some degree, but I personally find them more trouble than they're worth. Perhaps someone with better technique than me would get more impressive results.
Hope this helps.
Yes it does help, thank you, and certainly is sound advice to do the minimum required to rid yourself of a problem that is going to return regardless at some point. Good point on the sensor swabs and I will not buy cheap knock off's at least knowingly!
The only static brushes I ever used were for cleaning negs prior to printing so at this time without any resounding cries of you must get one as they are the best thing since whatever.. I will give them a miss - a fact that my pocket may appreciate, except that I will spend the money saved on something else
The Pentax gel solution is my first port of call to keep until needed. While the Eyelead may be the same or very similar maybe prudent to go with the manufacturers rec.
Thank you
Originally posted by photoptimist 1. Rocket blower (not canned air).
2. Gel pen.
3. Wet swab cleaning.
Whether you need an illuminated loupe is up to you. If you take a photo at the smallest aperture possible of an out-of-focus blank wall/blue-sky/sheet of paper and look at that image for dust bunnies, you'll get a much better idea of where the spots are. Just remember that given the projection of rays through the lens plus flipping the camera around to clean the sensor that a spot on the upper-right of the displayed image is caused by a spot on the lower-right of the sensor if you are looking down the throat of the camera.
(Regrading Visible Dust Artic Butterfly: The idea of bringing anything involving static electricity near the sensor gives me the heebie-jeebies. Maybe it's safe and maybe it's a good way to fry the sensor or camera electronics.)
P.S. I see BigMackCam posted first with the same advice.
Still valuable advice made even stronger by two recommendations
Canned air worries me for anything other than trivial equipment cleaning - the thought of the liquid propellant well...
Point well made, and taken onboard about static, electronics and sensor and knowing me the brush that spins like a whirling dervish when you press the button maybe a potential point of failure for me if attention wanders
Thanks
Originally posted by Dericali Some advice that I've picked up (that is generic and not specific to the 645z):
Using a air blower can often be all the cleaning you need. Make sure you have a dedicated blower for this, e.g. a blower for sensor cleaning that is kept in its packaging so it's not got any dust on it, otherwise it can blow this dust into the case. Use a high quality blower and not a no-brand one from China. (I have a second 'dirty' blower I use for lenses and filters).
Hold the sensor facing down when the mirror is locked up to reduce dust coming in. Perform in a dust-free room. E.g. a tiled bathroom rather than a carpeted bedroom. Also, if you run hot water in the room beforehand and fill it with steam, free floating dust will be collected by the steam and will 'clean' out the floating dust. So I normally clean my sensor about 15 minutes after a long shower
Thank you and yes I have a Rocket blower but intend to buy another just for this purpose.
