For over 30 years, I have had and used my Pentax 645 A 75mm f/2.8 with various lens hoods. It uses the same size 58mm diameter screw on round hood as the FA version.
At first, I was frustrated at how the Pentax, and invariably any collapsible rubber shade will separate from the screw on ring. I then used plastic or metal variants, but discovered I prefer a hood that will absorb shock and not possibly damage the lens ring because itʻs too rigid.
Currently B&H carries variations that will work from $6 on a generic, $7 for Sensei which includes a center pinch lens cap (helpful), B+W for $13, and a Heliopan for $34.
General Brand 58mm Collapsible Rubber Lens Hood NP11058 B&H Sensei 58mm Collapsible Rubber Lens Hood LHR-58 B&H Photo Video B+W 58mm #900 Rubber Lens Hood 65-069607 B&H Photo Video Heliopan 58mm Screw-in Rubber Lens Hood 71058H B&H Photo Video
The cheaper stuff uses a plastic ring which is more likely to cross thread if you constantly take it off and on, but metal rings can go out of round and seize as well and have their own pros and cons. The longevity of any of these has more to do with how often you collapse and re-extend them vs. leaving them extended. I am not a fan of any of the 3-in-1 type adjustable rubber hoods as they seem to never be in the correct length that I set it in. Just more hassle and potential for vignetting.
Some Pentax hoods (dedicated petal types with removable door for polarizers) make sense but are pricey. For this lens, however, I have used and donʻt see any benefit in buying the more expensive Pentax or Hoya versions.
