Originally posted by DandA
Steve, I very much appreciate your reply and explanations. I am familar with the T mode vs. B but unfortunately that was not the cause of the issue I described above. My physically pressing and releasing the shutter buttom in B mode should be emulated by the wireless cable release but with the wireless there was a second or two delay of the closing of the shutter. I dont recall this happening previously and still trying to rectify the situation. Again thanks.
Dave (D&A)
My pleasure. I have never been able to get "B" to work with an IR remote unless set to type "2". The expected behavior if set to type "1" is for the shutter to open and immediately close. If you have a remote that holds the shutter open when continuously pressed, that behavior may be unique to the 645Z.*
It would help if you identified the remote(s) you are using and the camera(s) they were made for. (Some third-party units are advertised as working with multiple camera brands/models.)
Edit: I did some additional research and apparently, behavior depends on the remote. The model "F" support continuous press, so apparently the protocol is rich enough for that feature. Sorry for the confusion from me.
* Your camera's operational settings are essentially similar to my K-3, otherwise I would not have commented.
