Originally posted by leekil These two statements seem to be in conflict; if you can't get more than 14 EV with a bit depth of 14, how can you get more than 8 EV with a JPEG, which has a bit depth of 8?
You cannot - your camera acquires images as raw data and this is converted in camera (or in post) to JPEG and in the process data is discarded either by the camera designers visions if left in camera or by your interpretation in post
You are looking at different things here one being the acquisition device which is limited by the analogue to digital converter (A/D) and processing software and the other being the file type and its limits. In the case of a camera system and the linear A/D conversion DR measured in EV cannot exceed the A/D conversion bit depth. So in an 8 bit camera you would not be recording any more than 8 stops in fact you may be limited to around 5 stops - which is about the same as some analogue slide film
A very rough and quick attempt at an explanation:
Dynamic range is the ratio between the brightest and darkest intensities recorded by your sensor as a linear capture.
Bit depth on the other hand is the number of bits per channel used to display distinct colour shades between the minimum and maximum
Your acquisition device (Pentax, Nikon, Canon)has a linear A/D converter and depending on camera this may be 12 or 14 bit system.
If it is a 12 bit device the limit is 4,096 levels which increases 16,384 levels @ 14 bit.
A typical chart showing the relationship between sensor bit depth below. Please note this is an ideal scenario but does illustrate DR expressed in EVs cannot exceed the ADC resolution expressed in bits. No account taken of the unacceptable noise levels that would occur after the 9th or 10th stop with 12 or 14 bit system - noise being subjective with one person accepting more or less than another
Bit depth relating to colour or grey shades is different as an example:
A JPEG 8 bits per pixel maximum number of colours available 256 per channel for a total of 16,777,216 colour shades (=24 bits: 8 red, 8 green, 8 blue)
Deep Color of 30/36/48-bit (10/12/16 bits per channel) consists of billions of colours e.g 16 bits per channel (48 bit) 281,474,976,710,656 colour shades
