09-03-2017, 11:13 PM   #1
Canon EF Mount lens on a 645??
Is this possible? I've been heavily invested in Canon EOS gear for a long time and shoot the 6D. Before you all laugh at what maybe a silly question :-D..... I'm a really recent 645 owner and I have the 80-160mm lens and....c'mon, it's a tank! I really wanted to enter the medium format world and the original 645 was my first fiscally responsible choice. I'm looking for something more mobile. I don't care about losing f/ function if that's the case. I mean, if it's a cheap adapter, I'll go for it just to experiment. All the adapters I've seen out there are for 645 lenses to 35mm fullframe bodies, but not the visa versa. Thoughts?
09-03-2017, 11:24 PM   #2
Otis Memorial Pentaxian
clackers's Avatar
Nathan, Canon have never made medium format, so for starters I can't see any of their lenses covering a big sensor like the one on your 645 ...
09-03-2017, 11:32 PM - 1 Like   #3
Short answer. NO.
The distance from the flange of the lens mount to the sensor plane is the important distance. Lenses designed for a camera with a longer flange to sensor distance can be mounted on a camera with a shorter flange to sensor distance by using an adapter to make up the difference between the two flange to sensor dimensions. So you can mount Pentax 67 lenses on 645, 645 lenses on Pentax K-mount or lenses on Canon EF mount. There are adapters for all these combinations.
Canon EF lenses have a shorter flange to sensor distance than 645 cameras. This would mean that the flange of the lens would have to be INSIDE the 645 lens mount to allow correct focusing. This is something that just would NOT work. You could construct an adapter with additional glass to correct for this situation, but no one makes them.
Regards
Chris
09-04-2017, 12:06 AM   #4
Your Canon glass can be mounted on the ML Fuji,plenty of dumb adapters and a recently anounced AF one by TechArt Pro.
09-04-2017, 03:38 AM - 1 Like   #5
clackers's Avatar
QuoteOriginally posted by surfar Quote
Don't do this, they'll need corrective glass!
09-04-2017, 09:27 PM   #6
672
actually there are a number of canon lenses that will cover a 44mm image circle quite comfortably.
09-04-2017, 09:36 PM   #7
clackers's Avatar
QuoteOriginally posted by 672 Quote
What were you thinking of, 672?
The OP has a 6D, so he probably has EF lenses.
09-05-2017, 10:42 PM   #8
Thanks clackers. I should've mentioned that my 645 is the original film version. Not sure if that makes a difference though - for mounting an EF lens on that body.
09-05-2017, 10:46 PM   #9
clackers's Avatar
QuoteOriginally posted by nathanduncanphoto Quote
It makes it worse, Nathan, because it will really be 6cmx4.5cm, right?
As I understand it, the 645D and 645Z use cropped MF sensors, about two-thirds the size.
09-05-2017, 10:47 PM   #10
QuoteOriginally posted by seventhdr Quote
Short answer. NO.
Regards
Chris
Thanks seventhdr1. I should've mentioned that my 645 is the original film version. Not sure if that makes a difference though - for mounting an EF lens on that body. Makes sense what you said though. That corrective glass on other ones makes a difference (like Canon FD to EF mount, etc).
---------- Post added 09-05-17 at 10:50 PM ----------
True true, I was thinking that just now. The D and Z sensors are considerably smaller than the 645 film image.
---------- Post added 09-05-17 at 10:52 PM ----------
Thanks everyone! Looks like I'll have to look at medium format options going forward.
09-06-2017, 12:52 PM - 1 Like   #11
baro-nite's Avatar
Some of the Pentax 645 lenses are excellent value and also quite compact. A150 is quite compact for such a long focal length, and IMO a great value (one of my most used lenses). Has a built-in hood. The 75 (either the A or the FA) is very compact for a MF lens, also a great performer, more expensive than the 150 but still a pretty good value. The A55 is also good, and not too large and a pretty good value.
09-06-2017, 05:40 PM - 1 Like   #12
645 A lenses are very cheap, and most primes are not that heavy or big, the zooms are another story.
09-07-2017, 07:08 PM   #13
QuoteOriginally posted by baro-nite Quote
Ya I was looking at the 55 or the 75 recently. I like those.
---------- Post added 09-07-17 at 07:10 PM ----------
QuoteOriginally posted by Pablo Villegas Quote
I agree with you. I was just trying to be cheap and use my current stuff if possible. But the Pentax-A 55mm & 75mm are rather great values and light.
09-11-2017, 08:59 PM   #14
672
i was stirring the pot a little bit. i know the OP wants to use his canon glass on pentax 645 AND his canon FF. not possible. my point was more that many canon lenses do in fact have an image circle that covers a 44mm circle. i have a canon FD 600mm f4.5 that i shoot on pentax 645Z. it was at some point chopped up for cinema use and covers 44mm quite comfortably.
09-12-2017, 01:34 PM   #15
clackers's Avatar
Being all manual it probably works fine for you, 672.
Don't know how he'd even have a working aperture with an EF lens.
645d, 645z, camera, canon, canon ef, distance, ef, ef mount lens, film, flange, glass, lens, lenses, medium format, pentax 645 lenses, sensor, sensors, value
For Sale - Sold: Canon EF 70-300mm f/4-5.6 IS USM, EF-S 60mm f/2.8 Macro USM (price reduced) beachgardener Sold Items 3 10-11-2014 02:55 PM
For Sale - Sold: Canon 40D with Canon EF-S 18-55 IS Lens + goodies! johnwdavisjr Sold Items 6 02-21-2014 02:47 PM
Pentax 645 - Canon EF/EF-S Adapter derAngler Pentax Medium Format 9 07-07-2013 11:07 AM
For Sale - Sold: Canon EOS 500D/T1i Camera + Canon Zoom Lens EF-S 18-55mm 1:3.5-5.6 IS mackloon Sold Items 7 08-13-2011 10:58 AM
All times are GMT -7. The time now is 01:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
