Originally posted by jnmullins my 645 decided it no longer wants to consistendddtly wind the film on to the next frame. The shutter fires fine, but I either have to remove and reinstall the battery pack several times until it finally decides to wind or to use a pair of pliers to manually wind on to the next frame.
If the shutter is firing but the film is not winding, it's not a power issue. I use lithium AA and if anything, they've been much better than alkalines.
Although what you describe has never happened to me, I had a student that had this problem and it turned out the gears were worn on his 645. But that doesn't make sense for you if you can manually wind the film. BTW: On the bottom of the 645 is a round knob that you can unscrew by hand or with a coin. This knob can then be inserted into the side of your camera for manual firing and film advancing.
I love the 645, but the electronics on it seem easily affected by electromagnetic fields. I'm not an engineer, but after 30 years and hundreds of rolls, I've been frustrated by the occasional "ghost in the machine". In Hawaii where the earth's crust is thin, and thus volcanic activity and magnetic-rich iron content red soil, I've had "anomalies" on active and dormant volcanoes (Maui and the Big Island). Alaska is on the "ring of fire" and also closer to the magnetic pole.
Years ago when I managed a photo lab, Noritsu would send us solar storm forecasts from Japan because their processors were affected during high solar activity and we'd have days where all kinds of anomalies would prevent us from reliably producing prints in an hour.
Now that you're home, have you run a test roll and does it still have the problem?
