Originally posted by barringtonpro I'm getting dates but they all refer to the photo. I don not see any camera manufacturer date.
Even if you upload an image to Friedl's site?
BTW, you need to send straight-out-of-camera image files to all these EXIF viewers, not edited ones.
This is the sort of thing you will see from EXIFTOOL:
ExifTool Version Number : 10.54
File Name : ex-pic07.jpg
Directory : K:/.../z/samples
File Size : 15 MB
File Modification Date/Time : 2014:06:04 11:42:40+10:00
File Access Date/Time : 2016:07:14 21:04:10+10:00
File Creation Date/Time : 2016:07:14 21:04:10+10:00
File Permissions : rw-rw-rw-
File Type : JPEG
File Type Extension : jpg
MIME Type : image/jpeg
Exif Byte Order : Little-endian (Intel, II)
Make : RICOH IMAGING COMPANY, LTD.
Camera Model Name : PENTAX 645Z
Orientation : Rotate 270 CW
X Resolution : 300
Y Resolution : 300
Resolution Unit : inches
Software : PENTAX 645Z Ver. 1.00
Modify Date : 2014:04:15 11:03:29
Artist :
Y Cb Cr Positioning : Co-sited
Copyright :
Exposure Time : 1/100
F Number : 10.0
Exposure Program : Manual
Sensitivity Type : Standard Output Sensitivity
Standard Output Sensitivity : 400
Exif Version : 0230
Date/Time Original : 2014:03:08 13:10:52
Create Date : 2014:03:08 13:10:52
Components Configuration : Y, Cb, Cr, -
Flash : Off, Did not fire
Focal Length : 55.0 mm
Pentax Version : 11.2.1.0
Pentax Model Type : 0
Pentax Model ID : 645Z
Date : 2014:03:08
Time : 13:10:52
Quality : Best
Flash Mode : Off, Did not fire; Internal
Focus Mode : AF-C (Release-priority)
AF Point Selected : Unknown (17); 0
ISO : 400
Exposure Compensation : 0
Metering Mode : Multi-segment
Auto Bracketing : 0 EV, No Extended Bracket
White Balance : Kelvin
DSP Firmware Version : 0.31.00.00
Effective LV : 11.3
Image Editing : None
Picture Mode : Manual; 1/3 EV steps
Drive Mode : Single-frame; No Timer; Shutter Button; Single Exposure
Data Scaling : 8192
Lens Type : smc PENTAX-D FA 645 55mm F2.8 AL [IF] SDM AW
Extender Status : Not attached
Sensitivity Adjust : 0
Image Edit Count : 0
Camera Temperature : 24 C
AE Lock : Off
Noise Reduction : Off
Flash Exposure Comp : 0; 0
Image Tone : Bleach Bypass
Color Temperature : 6200
Shutter Count : 3861
Raw Development Process : 14 (645Z)
Hue : None
White Balance Auto Adjustment : Off
Tungsten AWB : Subtle Correction
Dynamic Range Expansion : On; Enabled; 0; 0
World Time Location : Hometown
Hometown DST : No
Destination DST : No
Hometown City : Tokyo
Destination City : Tokyo
High/Low Key Adj : -4
Contrast Highlight : 0
Contrast Shadow : 0
Contrast Highlight/Shadow Adj : Off
Fine Sharpness : Off; Normal
High ISO Noise Reduction : Auto; Inactive
AF Adjustment : 0
Monochrome Filter Effect : None
Monochrome Toning : None
Face Detect : On (5 faces max); 0 faces detected; 1
Face Detect Frame Size : 2096 310
Shadow Correction : Off
ISO Auto Parameters : Standard
Cross Process : Off
Distortion Correction : Off
Chromatic Aberration Correction : On
Peripheral Illumination Corr : Off
Diffraction Correction : On
Bleach Bypass Toning : Green
Aspect Ratio : 4:3
HDR : Off; Auto-align Off; n/a; 0
Interval Shooting : Off
Black Point : 0 0 0 0
White Point : 18176 8192 8192 10624
AE Exposure Time : 1/93
AE Aperture : 9.9
AE ISO : 400
AE Max Aperture : 2.8
AE Max Aperture 2 : 2.8
AE Min Aperture : 23
AE Min Exposure Time : 1/3862
Auto Aperture : On
Min Aperture : 22
Lens F Stops : 8.5
Min Focus Distance : 0.49-0.50 m
Focus Range Index : 3
Nominal Max Aperture : 2.4
Nominal Min Aperture : 27
AE Metering Segments : 6.4 6.1 5.9 5.8 5.9 5.9 5.3 4.3 4.0 4.0 4.0 4.5 4.9 5.0 5.1 5.1 6.9 7.3 6.5 6.6 6.4 6.1 5.6 5.1 4.3 4.1 4.5 4.3 4.1 4.0 4.1 4.8 6.4 7.3 7.3 7.1 7.0 6.8 6.6 6.5 6.4 6.4 6.4 6.1 6.1 6.0 5.6 5.4 5.3 5.0 4.8 4.1 3.9 4.0 4.3 4.3 4.8 5.0 5.0 5.0 5.0 5.5 6.5 6.3 6.6 6.3 6.0 6.0 6.5 5.8 4.6 5.0 5.1 4.3 3.9 4.0 4.1 4.8 6.6 7.3 7.1 7.0 6.8 6.6 6.5 6.5 6.4 6.4 6.3 6.1 5.4 5.3 5.0 4.8 4.5 4.1 3.8 3.8 4.0 4.4 4.6 4.8 5.0 4.9 4.8 4.6 4.5 5.6 6.6 6.5 5.9 6.0 6.5 7.0 6.9 6.3 6.1 6.3 5.8 4.3 3.9 4.0 3.9 5.0 6.5 7.0 6.9 6.8 6.6 6.6 6.5 6.5 6.4 6.3 6.3 5.0 4.6 4.4 4.3 4.0 3.9 3.8 3.9 4.1 6.0 6.5 5.1 4.9 4.8 4.5 4.4 4.1 5.0 6.5 6.3 6.9 7.4 7.6 8.0 8.1 6.9 6.5 6.8 6.6 5.9 4.1 3.6 3.8 3.8 4.6 6.0 6.6 6.8 6.6 6.6 6.6 6.5 6.5 6.4 6.4 5.1 4.5 4.1 4.0 3.9 3.9 3.9 5.1 6.3 7.3 7.5 6.4 4.8 4.6 4.4 4.0 3.8 4.1 6.4 6.4 7.4 8.0 8.1 8.5 7.5 7.1 7.1 7.0 6.9 6.6 5.8 3.9
Flash Metering Segments : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Slave Flash Metering Segments : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Manufacture Date : 2014:01:15
Production Code : 2.1
Internal Serial Number : 1025
Power Source : Body Battery
Body Battery State : Close to Full
Body Battery Voltage 1 : 6.49 V
Body Battery Voltage 2 : 6.25 V
AF Predictor : 903
AF Defocus : 2
AF Integration Time : 0 ms
AF Points In Focus : None
Kelvin WB Daylight : 5205 0 2.0377197265625 1.429443359375
Kelvin WB 01 : 2500 0 1.1112060546875 2.5277099609375
Kelvin WB 02 : 2630 0 1.174560546875 2.4393310546875
Kelvin WB 03 : 2780 0 1.24658203125 2.329833984375
Kelvin WB 04 : 2940 0 1.320068359375 2.217529296875
Kelvin WB 05 : 3130 0 1.4024658203125 2.0960693359375
Kelvin WB 06 : 3330 0 1.4833984375 1.9847412109375
Kelvin WB 07 : 3570 0 1.5740966796875 1.870361328125
Kelvin WB 08 : 3850 0 1.6717529296875 1.759521484375
Kelvin WB 09 : 4170 0 1.7733154296875 1.6561279296875
Kelvin WB 10 : 4550 0 1.88134765625 1.55712890625
Kelvin WB 11 : 5000 0 1.9931640625 1.464111328125
Kelvin WB 12 : 5560 0 2.11083984375 1.374755859375
Kelvin WB 13 : 6250 0 2.228515625 1.2923583984375
Kelvin WB 14 : 7140 0 2.3460693359375 1.215576171875
Kelvin WB 15 : 8330 0 2.4599609375 1.1456298828125
Kelvin WB 16 : 10000 0 2.5667724609375 1.0828857421875
WB Shift AB : 0
WB Shift GM : 0
EV Steps : 1/3 EV Steps
Sensitivity Steps : 1 EV Steps
Serial Number :
Source Directory Index : 0
Source File Index : 0
Level Orientation : Rotate 270 CW
Composition Adjust : Off
Roll Angle : -1.5
Pitch Angle : -2.5
Composition Adjust X : -4
Composition Adjust Y : 1
Composition Adjust Rotation : 5
Contrast Detect AF Area : 0 0 0 0
Flashpix Version : 0100
Color Space : sRGB
Exif Image Width : 8256
Exif Image Height : 6192
Interoperability Index : R98 - DCF basic file (sRGB)
Interoperability Version : 0100
Sensing Method : One-chip color area
File Source : Digital Camera
Scene Type : Directly photographed
Custom Rendered : Custom
Exposure Mode : Manual
Focal Length In 35mm Format : 43 mm
Scene Capture Type : Standard
Contrast : High
Saturation : Normal
Sharpness : Soft
Subject Distance Range : Close
GPS Version ID : 2.3.0.0
PrintIM Version : 0300
Compression : JPEG (old-style)
Thumbnail Offset : 32138
Thumbnail Length : 7405
Preview Image Size : 720x480
Preview Image Length : 53166
Preview Image Start : 39620
Preview Image Borders : 0 0 40 40
Image Width : 8256
Image Height : 6192
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:2 (2 1)
Aperture : 10.0
Image Size : 8256x6192
Lens ID : smc PENTAX-D FA 645 55mm F2.8 AL [IF] SDM AW
Megapixels : 51.1
Preview Image : (Binary data 53166 bytes, use -b option to extract)
Scale Factor To 35 mm Equivalent: 0.8
Shutter Speed : 1/100
Thumbnail Image : (Binary data 7405 bytes, use -b option to extract)
Circle Of Confusion : 0.038 mm
Field Of View : 45.4 deg
Focal Length : 55.0 mm (35 mm equivalent: 43.0 mm)
Hyperfocal Distance : 7.87 m
Light Value : 11.3
-- press RETURN --
