Originally posted by Jonathan Mac If I could have had that option at only £30 more then I would have. Bear in mind that the shutter speeds on the 645 change in whole stops only so unless you change your aperture the meter might not be giving you a very accurate reading, even if the meter itself is accurate, because as it's reflected in shutter speed changes is not very accurate.
Does this mean that the modified version includes half stop shutter speeds as well? Otherwise, I'm not sure how much difference +/- half stop compensation would make when relying on the camera's meter, not unless it changes how the camera decides to round the shutter speed up or down. In any case I would assume the camera errs on slight overexposure versus underexposure.
Could you not easily accomplish the same thing by setting the ISO half a stop lower (rate 200 at 160, 400 at 300, etc.)?
---------- Post added 12-13-23 at 06:39 PM ----------
Originally posted by Hugo Bucussi Hello,
Sorry for bringing this one back to life after almost 6 years. But I didn't want to create another topic on this subject.
I've been shooting with my K-5 for quite some time now, but after watching many videos about film photography, I'm inclined to give it a try. I love my K-5 and the lenses I have, so I was looking to purchase a Pentax 645. I saw a couple of them with this manufacturer mod and was thinking if this is really a bonus and worth paying the extra +/-£30 for it. I definitely won't be using the CONTINUOUS shooting option that the original ones have, so it might be worth the extra +- EF function.
I think you could accomplish the same thing by changing the ISO (very easy to do on the 645), it has a huge range of ISO settings. As for film in general, in some ways it's very different from digital. For example, there is a tendency to rate exposure for highlights and not shadows because it's difficult to recover highlights with digital. The opposite is true for film.
If your budget allows, I would recommend also buying an inexpensive 35mm SLR with a short/mid prime lens (say 35mm or 50mm) so that it will be more affordable to learn. 120 and 35mm are roughly the same price, but you'll only get 15 exposures from the 645 whereas 35mm is 36 exposures. There are some really great manual SLRs available for very little money. A while back I bought a Minolta XG9 for $30 on eBay and it included a 50mm lens. I'm currently still using that camera regularly.
