03-06-2018, 03:14 PM   #1
mattb123's Avatar
Pentacon Six adapter cap stuck
I just got a Pentacon Six to Pentax 645 adapter and it came with what appears to be a Pentacon body cap on that side. My problem is remivning that cap! It seems very firmly attached and I can't unscrew or pull it off. I don't want to force it and damage something so I thought I'd ask if anyone knows a trick to remove that cap.
The auction it came from is here.
The third photo there is how my adapter looks with the cap on. How to I remove it?
Here's the photo from the auction.
03-06-2018, 03:36 PM - 2 Likes   #2
QuoteOriginally posted by mattb123 Quote
The P6 mount is a breech-lock design. Install it on a Pentax body, and the turn the knurled ring. It will turn about 1/3 turn, and then the P6 lens or body cap will lift straight off.
Breech lock is “insert and turn lock ring”, not “insert and twist” as with most bayonet mounts.
Rick “a common misunderstanding” Denney
03-06-2018, 03:42 PM   #3
IgorZ's Avatar
I have the same adapter. It should work as Rick described.
---------- Post added 03-06-18 at 03:44 PM ----------
Alternatively, if you hold the cap in your left hand and turn the adapter ring clockwise, I think it should come off
03-06-2018, 03:54 PM   #4
QuoteOriginally posted by IgorZ Quote
Only if you turn the knurled ring with the other hand. If you try to turn the mount while holding the cap, you’ll be trying to shear off the alignment tab on the cap.
Rick “only the Hartblei 1008 has a twist-and-lock implementation of the P6 mount” Denney
03-06-2018, 06:29 PM   #5
IgorZ's Avatar
QuoteOriginally posted by rdenney Quote
Exactly. That is what I meant
03-06-2018, 09:26 PM   #6
mattb123's Avatar
Yes! Thanks you all. Got it figured out. Now I have a working wide for my 645 systems again.
03-06-2018, 09:45 PM   #7
Glad it worked. The fun part of that body cap is using it as a lensboard on the front of a Pentacon Six bellows.
Rick “who did that with a B&L copy lens” Denney
03-28-2018, 09:03 AM   #8
The P6 mount is a breech-lock design. Install it on a Pentax body, and then turn the knurled ring CCW from the front. It will turn about 1/3 turn, and then the P6 lens or body cap will lift straight off.
Thanks, Rick, this advice was extremely helpful. I have highlighted some additions to your text that I think will make it even clearer.
645d, 645z, adapter, auction, camera, cap, medium format, pentacon, pentacon six adapter, photo, six, six adapter cap
Pentacon Six > K Mount Adapter Topsy Pentax SLR Lens Discussion 22 01-19-2016 05:40 PM
For Sale - Sold: Tilt set-up ARAX tilt adapter Pentacon Six to Pentax K + Carl Zeiss Flektogon jephi Sold Items 2 07-23-2011 10:47 PM
For Sale - Sold: Tilt lens set up: MIR 45mm f/3.5 (Pentacon six) and tilt adapter Nick Siebers Sold Items 6 05-04-2011 04:20 AM
Zeis Sonnar 180mm/2.8 Pentacon six ustinof Pentax SLR Lens Discussion 2 06-02-2010 05:53 AM
All times are GMT -7. The time now is 09:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
