Originally posted by johnha Hi All,
I've just acquired a 6x7 S-M-C-Tak 135/4 macro lens, although described as having a 'snappy' aperture, it isn't as snappy as my other lenses (possibly a couple of visible spots of wear/oil on the blades). I have no doubt it should be snappier (the blades can be seen moving - it's not instantaneous), but for the price I paid and considering the age of the lens I'm tempted to keep it (my second body only meters stopped-down anyway). So the question is, what problems might I expect?
I can't seem to work out whether the camera holds the aperture open (letting the spring close it before exposure) or drives it closed (letting the spring open it after exposure)?
Regards,
John.
I had one of those sluggish 135/4's as well. I had it CLAd but it didn't help - I suspect it was a weak spring, not oil on the blades. I finally sold it for pennies on the dollar and bought one in great condition.
If the aperture blades are slow to close, you risk over-exposure: The shutter will fire before the correct aperture is reached. This problem usually is irrelevant if you switch the lens to MAN before you fire, as MysteryOnion says. As well, the MLU will close the aperture in advance. And if you're planning to shoot wide open it will be irrelevant. So there are several shooting situations where sluggish stop-down won't matter. But if you want increased depth of field and you don't want to take the time to switch to MAN or to trigger MLU, it's best to give up on this copy of the lens and to try another sample.
Regards,
Sterling
