03-13-2018, 07:36 AM   #1
Pentax 67 shift lens with adapter to 645Z
Has anybody ever used a Pentax 75mm 67 shift lens with an adapter on a 645Z camera? I didn't know if there would be image cutoff because of the adapter itself on the image circle. It looks like I can get reasonably priced 67 TS lenses and am perfectly happy to use them manually. I usually use a spot meter anyways.
03-13-2018, 08:11 AM - 1 Like   #2
I’ve played with it and didn’t notice any cutoff on a 645NII. I can look more closely to be sure when I get back in town.
The Arsat 55mm PCS lens likewise does not cut off even at full shift, using an adapter to fit it to a Pentax.
Rick “thinking the Arsat is a better focal length, better mechanically, and just as good optically” Denney
03-13-2018, 02:02 PM   #3
QuoteOriginally posted by rdenney Quote
55mm? Is this correct or a typo?
I see the existence of this is noted at https://www.pentaxforums.com/forums/48-pentax-medium-format/182276-pentax-me...ft-lenses.html, but is not shown at araxphoto's site.
More exactly, it is not shown in their list of available lenses, but the underlying data can be found by an external search. Price is listed as N/A, so they must have run out of Kiev Arsenal parts.
03-13-2018, 02:13 PM   #4
I'm just starting to play around with a P67 45mm on a Zoerk Pro Shift adapter. Nice. The P67 55mm (late version) is supposed to be sharper than the 45mm but I was keen to go below the 50mm barrier.
I used to have an Arsat 55mm PCS (in Pentax mount) but I found that it was quite soft. The Mamiya 50mm is WAY sharper. To my shame, I sold an extremely rare Mamiya 50mm lens IN PENTAX MOUNT!!
I'm wondering how a P67 35mm fish eye lens would shift on my Zoerk!
03-13-2018, 02:50 PM   #5
QuoteOriginally posted by kaseki Quote
You probably already found the description:
http://www.araxfoto.com/lenses/arsat-55-shift/
Unlike the 45 and 65 lenses, the 55 was purpose-built to be a shift lens. It came out very late (90’s) and is a fairly modern design, by the standards of that factory. Optics are excellent, and the shift mechanism works more smoothly than my Pentax shift lens. It has a preset aperture with a cable-release socket to allow stopping down with a double release.
Arsenal has been closed for about 15 years, so these have to be found on the secondary market. I bought mine from Arax at least ten years ago—it was my last lens in the P6 mount.
Rick “who also has a Hartblei 45mm PCS lens” Denney
03-14-2018, 12:00 AM   #6
Arax Photo | Lenses | MC ARSAT PCS 4.5/55 Shift Medium Format Lens.
Hi Rick - just noticed you have the Hartblei 45mm...I have one too (marked 'Digital' on the lens front).....how does it compare for image quality vs the Arsat 55mm shift? Regards, Ian (in UK - using the 645Z)
03-14-2018, 04:44 AM   #7
The cutoff (darkening) fades in at about 10mm shift on the Z when using the 67-75mm on a Pentax adapter.
Bob
03-14-2018, 08:39 AM - 1 Like   #8
QuoteOriginally posted by BostonUKshooter Quote
It depends on the example, but good 45’s can be quite decent in the center. The 55’s are more rare and their consistency is not known. My 55 was about the same as my (very good) 45 Hartblei PCS in a big MTF test that a group of us Kiev collectors conducted maybe a decade back. I’ll know more when I get the Z (waiting on my birthday), and can do better tests more easily.
http://www.rickdenney.com/mother_lens_test.htm
The center performance of the 45 was apparent in this test, where I used a tilting adapter on a Canon to turn the shift lens into a tilt/shift lens.
http://www.rickdenney.com/tilt_shift.htm
Rick “old stuff” Denney
03-14-2018, 01:47 PM   #9
Kiev Cameras
Kiev Cameras
Thanks Rick - all understood - would be interesting to see your test results when you get the 645Z!
I have the 25mm, 55mm and 90mm DFA lenses for the Z , and they give astounding images.....also the 300mm ED M* 67 lens (+ Fotodiox adapter) does an amazing job for an 'old' lens.
Regards, Ian
03-14-2018, 08:03 PM   #10
QuoteOriginally posted by Bob L Quote
Bob
Thanks!,
Thats kind of what I expected.
645d, 645z, adapter, camera, image, lens, lens with adapter, medium format, pentax, pentax 67 shift, shift, shift lens, tilt / shift
67 75/4.5 Shift for shift panoramas? CreationBear Pentax Medium Format 32 04-12-2018 06:46 AM
Pentax 67 75mm shift lens usage query csanjay Pentax Medium Format 8 03-27-2016 07:01 AM
67-645 adapter and 645Z BBC5 Pentax Medium Format 11 12-23-2014 08:02 PM
P645NII, 67>645 Adapter, 67 Auto Extension Tubes? ASA32 Pentax Medium Format 4 05-24-2013 09:27 AM
645 or 67 lens to be used w/ tilt shift adapter? gsrokmix Pentax SLR Lens Discussion 9 07-28-2012 05:11 PM
All times are GMT -7. The time now is 11:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
