03-21-2018, 02:34 AM   #1
How to use the plugin v2.0 for P645Z
Object : tethered shooting with Image Transmitter 2 and P645Z
Hello,
I have observed that there was 2 plugins for P645Z :
Version 1.20 (called "simple version")
Version 2.00 (for working in conjunction with IT2)
I have the 2 plugins installed in Lightroom, but only one may be active at a time. So, I only activated the one i want to use, and desactive the other. There are also 2 .PDF file which should normaly help the consumer to use them, but they are not very well written and difficult to understand. As the second plugin do not work on my computer, i somewhat frustated ... is it something that I do not undestand ?
The simple version is working correctly with Lightroom 6, but there is no way to control aperture or speed or iso through Lightroom, but only directly on the camera. There is a bar on which the iso, speed, aperture appears and a push button. Better than nothing, but there is a second plugin.
This second version, which is normaly made to work in conjunction with IT2 (Image Transmitter 2), do no work on my computer: a frame for the taken images appears on the screen of lightroom but remain always empty and no images are truthly transferred in the destination folder. The same bar appears (speed/iso/aperture/push button) but the information do not appears and are replaced with the mention <IT2>. The push button has no effect (impossible to taken an image). If i use the IT2 push button on the IT2 software, the camera take an image which appears in IT2, but never on Lightroom (the bar on lightroom let a wheel appears which turns indefinitively, a frame is drawn on the lightroom's screen in which the picture would normaly appear, but this reserved frame on lightroom remains empty). And after each shoot, there is a new empty frame which appears on the lightroom screen ???
I know that i could use another way to import pictures in lightroom with IT2 (hot folder), but i would be happy to know how to use the 2nd plugin.
Has somebody already tested this 2.0 plugin with success ?
if Yes, how to process ?
Thanks in advance
B SULMON
03-21-2018, 11:09 AM   #2
Having used v1 successfully, I took a look at the v2 manual and it looks like it works as follows:
-shooting settings are controlled via IT2 (thus you won't see aperture or shutter speed in lightroom)
-images are saved directly to lightroom
Make sure IT2's output folder is outside of your lightroom workspace, as otherwise I think you'll experience issues with one program trying to operate on a locked file. IT2 will automatically delete the files it saves in this mode, once they're imported into lightroom. This could potentially be what's causing the trouble in your case.
Also, it wouldn't hurt to upgrade the camera's firmware in case you haven't already.
03-22-2018, 07:50 AM   #3
Thanks for the answer, but this seems not to be the solution. I have used a repertory on disk F: as destination for IT2 (which was not mentionned in the workspace of lightroom), but i only get a new empty frame in lightroom after each shoot as before.
Il will stop to try to use this "IT2 Plugin", as i can shoot tethered with IT2 and automatic import with the "hot folder" of Lightroom
It's however strange that this plugin is not working.or that the way to use it is not much described.
Bye
bar, button, camera, dslr, frame, image, it2, lightroom, pentax 645z, photography, plugin, screen, tether shooting, version
Focus-Point Lightroom plugin for Pentax: we need your help! roguephysicist Digital Processing, Software, and Printing 31 09-19-2020 01:06 AM
Applying Masks with Topaz Plugin through PS BruceBanner Digital Processing, Software, and Printing 3 02-13-2018 02:17 PM
Theta S video using FCP X plugin Revolve360 John Araki Ricoh Theta 360 Cameras 2 06-16-2016 09:49 PM
P645Z and 28-45mm lens for landscape astrophotography Femtometer Pentax Medium Format 10 03-28-2016 01:32 AM
V2's Pocket wizards, Skyports etc Which do you have and use? Peter Zack Pentax Camera and Field Accessories 24 05-24-2008 05:59 PM
All times are GMT -7. The time now is 03:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
