Originally posted by cmohr Hey, No affiliation with them , but some cool stuff that could certainly be used to make the sort of thing you are wanting, And, pretty sure those wooden handles would make it easy to hollow out and fit in a release button.
camvate | eBay Originally posted by Ray Cox Thanks cmohr. There are some interesting pieces there. Still working on it! I am leaning toward "3 Legged Thing" parts at the moment. I am hoping to incorporate an electronic release.
You two triggered a thought with those comments that applies to the Samigon handle. As you may see in the two photos above, there is a 6-mm hole below the thumb position. This is lower end of a diagonal through hole that tapers to 8-mm, exiting under the index finger. I now wonder whether Samigon had a release (probably mechanical when it was designed) that fit that hole. I haven't been able to find a historical Samigon catalogue that might shed some light on the features of the grip.
