Originally posted by johnha Hi ivanvernon, have you managed to get hold of the Pentax adapter and been able to try it? I'm trying to work out if the 90 L/S will work using the Pentax adapter (also the 75mm shift which doesn't have an aperture lever). The Pentax adapter manual suggests these lenses won't work (although why is puzzling me).
Yes, I now have the Pentax brand 67-645 adapter in hand. I have also tried the Pentax 67 165mm f 4.0 LS lens, using the adapter, on my 645Z camera. The results are as follows: The camera/lens/flash appears to be working correctly: (1) the flash fires and (2) the LS shutter closes. The entire process appears to work in a coordinated fashion. However, no image is created. I only get a blank screen. I get this same result at all LS shutter speeds (60, 125, 250, and 500) and at all on-camera firing modes (M, B, X, TAv, Av, Tv, and Sv). It is encouraging that the camera, lens, and flash appear to work in a coordinated fashion, but a mystery that this apparently successful process does not yield an image. Any thoughts or suggestions can offer will be gratefully received.
