Originally posted by abruzzi I've never used the lens, but I was under the impression that stop-down metering should work. The aperture selection is transmitted to the TTL finder through the metering chain (on the 6x7 and 67). Because of the shift there is no mechanical way to pass that back to the camera, so It should only meter on actual light. So you would set the aperture and shutter speed to get the meter to give you a good reading. If you close down the aperture during this process the viewfinder will become dark and unusable, so once exposure is set, open the aperture up, focus, stop it back down and take the picture. The preset ring is used so you can easily stop back to your metered aperture without having to look at the lens. Is this what you're doing and its not working?
The preset & aperture rings are working as described - the lens does not have the aperture simulator mechanism (which connects to the meter chain on other lenses). The lens mount is similar to the Auto Extension Tubes (but without the stop-down lever as I'd expect). As I understand it, stop-down-metering is activated by switching the lens AUTO/MAN switch to MAN - this changes something to do with the pin at 3 o'clock on the lens mount. This lens does not have the AUTO/MAN switch (which makes sense), so it should always be in stop-down mode - except there's no movement from the meter. The lens itself has no moving parts to the mount (as I'd expect), so it's not like anything is missing or broken, the machined notch where the 3 o'clock pin connects looks fine and similar to those on my Auto-Extension-Tubes.
It may be a body/prism issue - I have two body/prism pairs. One pair meters in both open & stop-down modes, the other only in stop-down mode - swapping bodies & prisms leaves neither metering in any mode (I've given up trying to reason why!). Neither pair will meter with the Auto-Extension-Tubes in any mode - which sounds very similar to the problem I'm having with the 75mm Shift lens.
