Originally posted by abruzzi If anyone else has this lens, can you tell me, is it as loose as mine? Is there a trick I'm missing? Do you just live with it, or there a trick to fix it without disassembly?
Nope mine (67 300/4) is fine and has resistance, so your's will need fixing. The problem you have is the same as with my 35mm K300/4, the hood was loose so I sent it to Eric and he fixed it.
Yes I believe you are correct and there is felt that has worn out, same as with the old metal push-on lens caps.
Phil.
