Thanks you all for replying so quickly! Hereby a crop from the image, the stripes are vertically in the center of the frame.
I checked the negatives and I can't find the stripes in between the frames. Which probably excludes that there would be something in the chamber scratching the film. I talked with a guy from
kamerazeit.de and the mentioned that the curtain (he mentioned the small metal thing that pulls the curtain) might have a slight light leak which projects light on the negative while forwarding the film. If that is true, it would help when I would put on the lens cap when forwarding the film. I will try that next week and see if that solves the problem, will post that here!
Also if that is true, repairing is not an option as these curtains are not being made anymore.
These lines cant be from the lab as I got the films developed in two different labs and got the same results.
Also can't be from the flatbed scanning as the lab did the scanning with their fuji scanner.
Henk
