Originally posted by BostonUKshooter
Hi Rick - after seeing this, and our other discussion today about the 2x converter , I'm tempted to go in this direction rather then either of the 300mm options.....the 400mm would be a similar fov to a 320mm full-frame,correct? Thks, Ian
Look at my review of the 1.4x converter. I found that even though the 300/4 A* is better at f/11 than the 400/5.6 FA, it's not quite as good when put in front of the A 1.4x converter. I would use the converter in situations where I needed to optimize for 300 but also have a 400 capability (300*1.4=420) without having to crop, and particularly when I'm trying to lighten the load. But if I need to optimize at 400 and still have a 300 capability, then I will take the 400, and then maybe the 200 plus the converter (the 200 is much smaller and lighter than the 300, at least the A* 300).
400 is 400 is 400. It will project that distant object onto the sensor exactly the same size as a 400 on a 24x36 camera. The difference is that the 645 will see more of the scene around the edges. Also, different sensor densities will present different enlargement possibilities (assuming the lenses are good enough). For example, my wife might use a 400 on her D500 (APS-C), and I might use this lens on my 645z. If we are only interested in the face of the squirrel we are both photographing, and assuming that we can both see all of the face we want to, her camera will have more pixels in the face than mine will, because the pixel density is (a little) higher on the D500 sensor. If we both enlarge to make a 300 pixel/inch print, her squirrel face will be bigger than mine, but her print will be 12x18", and mine will be 20x28" (nominally). With her older D300, which has the same sensor size as the D500 but fewer pixels, the biggest 300ppi print she could make would be 9.5 by 14.5", and the squirrel's face would be exactly the same size, because both have the same pixel density. So, she'd have a squirrel face, say, 6" tall on a 9x14 print, and I'd have a squirrel face 6" tall on a 20x28 print. So, it's really a complicated comparison when we change formats on real cameras that have different sensors with different pixel densities.
And then the different shape of the format also has implications. If you are normally interested in the long dimensions (such as those who do panoramics), 24x36 will capture more of the scene compared to 33x44 than if you are interested mostly in the narrow dimension. If you normally frame to standard photographic print sizes (8x10, 11x14, 16x20, 20x28, etc.), you'll be more interested in the narrow dimension. If you only show pictures on the internet or on a 16x9 monitor, you may not care or you may be more interested in the long dimension.
Focal length controls the magnification in the camera, while the format (sensor size, not density) controls how much of the scene will be recorded. Pixel density, sensor noise, and lens quality determine how much the image can be enlarged (i.e., magnification
outside the camera).
The common method of comparison is to look at the length of the lens as a ratio to the diameter of the format. The diameter of 24x36 is 43mm, and the diameter of 33x44 is 55mm. 55/43=1.28. So, on a 645z, a 400 is 7.3 times the format diameter, and on a 24x36 camera, 43 times 7.3 is 314. But there's far more to the comparison than that.
Rick "answering a much larger question than the one you asked, but having his own preferred way of explaining it" Denney
