05-26-2018, 07:24 PM   #1
Pentax 67 Frame Counter Issue
Hi,
I just got a P67 and everything seems to work fine except for the frame counter. Initially after my first test roll, the counter reset to zero, not the largest dot to the left. I shot two more rolls and now the frame counter resets to 3. I can move the counter forward using the small button in the middle while the back is open, and as soon as I let go of the button, it resets back to 3. While shooting it seems to be more of an annoyance than a serious problem since itís harder to keep track of how many frames I have left. I developed two of the rolls and there arenít any issues with spacing.
Has anyone had this issue and is it something easily fixed? Iím a bit worried that it reset to zero and now 3, will it keep moving to higher values until it wonít move?
Iíve notified the seller and theyíre willing to work with me, but should I just send it back?
Any and all ideas are welcome and thank you in advance.
05-28-2018, 12:37 PM - 1 Like   #2
QuoteOriginally posted by John C. Janus Quote
Hi,
So upon further investigation, the top piece of the frame counter shifted about 30 degrees. I rotated it back and tightened the three small screws around it. Now resets to the largest dot, problem solved.
05-29-2018, 08:32 AM   #3
Thanks for documenting a repair.
645d, 645z, button, camera, counter, frame, frame counter, issue, left, medium format, move, pentax 67 frame, reset, resets
Pentax 6x7 frame counter will not advance tambrico Pentax Medium Format 5 08-04-2016 04:59 PM
K1000 frame counter stuck Robert Rodriguez Pentax Film SLR Discussion 5 11-19-2015 04:19 PM
Frame counter won't reset k1000 IrisA Pentax Film SLR Discussion 3 05-17-2012 04:03 PM
Pentax MX Frame Counter Stuck At Beginning iht Pentax Film SLR Discussion 14 01-30-2011 03:46 PM
Used parts source? (K1000 frame counter dial cover) ismaelg Pentax Film SLR Discussion 3 12-16-2009 05:54 PM
All times are GMT -7. The time now is 11:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
