Originally posted by kaseki This has been an interesting discourse. It also made me realize that I knew nothing about the 75LS lens. So I looked into it and discovered some ambiguity in directions for its use with flash. Perhaps one of you could translate this English statement from Page 8 of the LS lens instructions:
"Precautions on flash photography using X sync socket:
When an electronic flash is used in the lens shutter mode, connect the cord to the X sync socket. When using a dedicated Pentax clip-on type electronic flash, utilize Hot-shoe Grip, 4P sync cord C, etc. available as optional accessories. ..."
Evidently, this direction is tailored to the 645, as the 645N uses 5P flash cables, and doesn't require the Hot-shoe Grip because it has a hot shoe on the finder housing. What I am questioning is when using the leaf shutter and a Pentax dedicated flash, e.g., AF500FTZ, whether an X-connector cable is used on the 645N from camera to LS lens, or does the camera control the lens shutter through the camera-to-lens interface contacts while controlling the flash through the hot shoe (or any 5P cable)?
My second question is if the LS lens shutter is controlled by the camera via the lens contacts, does TTL work on the flash? Even 1/500 second (2000 microseconds) is long compared to typical flash quench timing in TTL.
Thanks
The LS lens does not need the contacts, and may work better with them taped over. It is triggered by the stop-down lever. When you press the button, it stops down the lens, which closes the leaf shutter, opens the focal plane shutter for 1/8 second, during which it releases the leaf shutter, which then remains closed until it is cocked with the ring on the lens.
The flash contacts and hot shoe on the camera are not used during leaf shutter operation, and the LS lenses do not support TTL or P-TTL automation. The flash is attached via PC cable to the PC connection on the side of the lens, which is triggered by the leaf shutter at the appropriate time.
All of this is triggered when the camera stops down the lens, so it (supposedly) works on all generations of 645 cameras. My 645z doesn’t coordinate properly with the lens unless I tape over the electrical contacts, which is a known issue.
The lens can also be used with the focal-plane shutter.
Rick “who has used it with studio lights quite a bit, and with Vivitar flashes” Denney
