Series Contents
For the general history of the Ukrainian PCS lenses, see Grand Lens Test 7.
Arsat is the generic brand name for Zavod Arsenal, the large defence manufacturer in Kiev that also made cameras and optics. The last lens they designed was this 55mm lens designed to provide coverage for movements. Thus, unlike the Hartblei conversions of regular lenses, this 55mm Arsat was purpose designed to be a shift lens. They were first shown at Photokina in 2000--the last gasp of the photographic innovation and production at Arsenal. There is a good description and history of these on Pentax Forums
here.
Mine is serial number 885 from the year 2000.
These have a manual aperture, but unlike the Hartblei, they have an aperture switch ring that allows one to set the aperture, and the switch between that set aperture and wide open. It's not quite like a present lens, and it can also be switched using a cable release screwed into the side of the lens.
Barrel quality of these is decent and the lenses are thoroughly multicoated.
Mine is in a Pentacon Six mount and adapted to Pentax 645 using an adapter from Hartblei.
Here it is, shown at full shift:
These are reportedly excellent. A lens of normal focal length with shift is nearly as useful as a wide-angle lens, but it should be noted that this is a wide-angle lens on its 6x6 native format. In the 645z world, it has to compete with the superb 55/2.8 DFA AW SDM and all the rest of the alphabet, and the only advantage it is likely to offer (except for weapon value in case of a mugging) is its shift. But, nevertheless, that's not without value, so the test proceeds.
Here's the main full view, unshifted, from the Arsat, at f/11:
Let's compare with the 55/2.8 and see what looks different even at this degree of downsampling:
It seems to me that the Pentax 55 has a slightly shorter focal length than the Arsat, but they are close. The Pentax is contrastier, which is obvious to me despite the difference in exposure. And the camera clearly perceived the image a bit darker with the Pentax lens, metered wide open, than with the Arsat lens, metered stopped down.
Here's a center crop at f/11:
This is not too bad, to be sure. How does it compare to the 55/2.8?
Okay, the Arsat is not nearly as good. So, those who say the Arsat is excellent may need to redefine excellence. It's
good (remember, at 100 pixel/inch of most monitors, these clips come from a print seven feet wide)
, but the Pentax lens is clearly
better. The Pentax lens is also more contrasty, apparent even despite the differences in exposure between these shots.
At f/4.5, the Arsat doesn't look good at all. Here it is in the center:
Does this lens have curvature like the 45? Here's the left edge at 4.5:
Nope--the edge of the grass is about on the focal plane, and it's about as sharp as this lens gets wide open, while the foregound Azalea bush, which would be sharp no the 45mm Hartblei, is appropriatelly out of focus here.
Here's that left edge at f/11:
This is better, about as good as in the center.
And seeing how the stopped-down photos are a bit over-exposed compared to the wide-open photos, I begin to think that on this dim day, with the meter looking through a lens at f/11, it just wasn't reading as accurately as the same meter through f/4.5 or f/2.8.
One fault I am NOT seeing is lateral color. This lens is actually quite well corrected for color, which is most useful for a shift lens where adjusting for lateral color requires an off-center algorithm that defeats image software.
But it's a shift lens, so let's shift it. Here is the full image at f/8, shifted 12mm to the left:
Let's look at 1:1 crops from here and there around the image.
Here's the upper left corner at f/8:
No field curvature here. The leaves that are in focus are about in the focus plane. This isn't actually all that bad, considering the level of enlargement. It's not in the same class as the Pentax lens, of course, but this is actually quite usable. And some judicious sharpening would make a big difference, too.
Here's the left edge, again at f/8:
Clearly, the foreground foliage is out of focus, but in the focus plane it's not bad.
Here is the point at which the lens was focused before it was shifted (the focus confirmation does not work well with a shifted lens--a common problem with phase-detect autofocus):
It appears to me that the lens changed focus slightly as it was shifted, but it's not because the focus ring turned. The shift mechanism may be just slightly out of alignment. That's certainly the sort of problem Arsenal is well known for.
Here's the center of the shifted image at f/8. The focus plane seems definitely a bit behind where it was focused:
My conclusion is that this is a much better lens than the 45mm Hartblei, which is to be expected simply because the Hartblei was not designed to be a shfit lens. For the purposes of this lens, being soft wide open is no problem--most of the time it will have to be stopped down significantly to get acceptable depth of field. Thus, this is a tripod lens, and I will use it only when I actually need the shifting capability.
I don't think this one will go to Alaska. I'm just not sure it's worth the weight without that specialized need. Plus the DFA 55 has to go--it's an all-weather lens, it's by far the fastest focusing lens I own, and it's just too good to leave behind.
Rick "Usable but not world-class" Denney
