when speeding up a object lets say a bullet over a explosion it speeds up pretty fast
when speeding up due pressure or force like a rad rotating mechanism or compressing air or a reflexing material
i can think that of a mechanical shutter ?
knowing about a rail gun from some experiments you can carry or speed up something that you useally cant move so fast because it would crush
going back to a shutter here what is if we use a neodym magnete in sence of a rail gun in small size so we reach a better shutter y-sync speed ?
thinking about this having a second blade coming up to the middle also would double the y-sync speed , if they also come from left and right it would fix that even better - but that sounds like a leaf shutter to me
if the answer is that on a flash and the electronic shutter would just recharge the sensors pixels
and the electronic shutter if the pixel sensor drains the charge - why would that have to do it again ? the sensor pixel just gets marked as "ignored" "used" or "not overstepp" again
1/125 is just bad to be honest its not only my meaning , it also has a other positiv effect when the pixels are charged the close down also happens faster that means less time or motion blur also comes for this "next part" of y-sync speed
1/30 open 1/125 to close it up , thats also something that would count
the thing with the light 380-700 nm (photon size bounce) is that the light is coming also in form of a wave lets say our sensor pixel got 380 nm so if the sensor pixel is flat that means the light could bounce to a other pixel according the position was not in the middle of the 380 nm sensor pixel part
then some part is on the other sensor pixel this means also a smaller size can make sence then this information is also covered and 2 positions can be combined
the bounce size or wavesize is known but the position it hits is not , its probaly about the quarks
what i meant with the hasselblad was not the mirror it was rather that the megapixels go up the old phase 1 from 2011 also already had 80 megapixels now 400 megapixels its 2018 after all
the viewfinders have a focus seeker and a depth of field seeker it marks them useally with blinking also it can warn with blinking over overlight and show a histogramm ect. the pecision is also better because you can zoom in 16x that allows you to set a very precise focus
the only advantage i can see at the moment in real time depending on the electronic lcd display its a bit delayed - but i accept new information here or more its even wanted
but that got better a bit framerate or refreshrate, reactiontime would be a keyword there is room up to improve here
how fast the y-sync speed of the electronic shutter for the pentax 645z really is ? on the video mode you can set 1/500 but i have no idea what the sensor really do here
also a idea would be a flash with LI-ION batterys this would offer more power with less weight
