Originally posted by zzzxtreme
thanks both of you. Much appreciated
Im not sure if I understand the "stop down metering" thing though.
I usually shoot A mode, setting the apeture with the aperture ring. I'm a newbie in film, right now shooting nikon AI lens with F601. That one doesn't have dof preview button.
So I'm still kinda confused. Is stop down metering necessary with A mode with lenses that doesnt have communication with the body?
Slide the mechanical slide switch on the lens to “M”. Use Av or M on the camera, with the lens set to the aperture you desire. You may not get a meter reading in dark conditions with small apertures—the finder will be dark. Focus before stopping down, or open the lens back up to focus, and then stop it down again before making the photo.
With the Pentax adapter, that lever communicates the lens’s aperture setting to the camera body automatically, and you can meter wide open with the slide switch on A. (There is no A setting on 67 aperture rings, and that setting means something different in any case.) But you still must use Av or M.
The 645z will insist on using Av or M, and will change a Tv or P mode to Av if it can’t control the lens aperture, which it can’t for non-645 lenses (645 lenses have the required A setting on the aperture ring).
Rick “remembering when an auto-aperture was a major new feature” Denney
