I played with the Digital Spotmeter today after reading the manual.
I compared it to everything I had from a canon 50d, two Pentax Super MEs, Liecaflex SL, Canon A2E and the 67.
All were within 1/3 stop of the Spotmeter except the Leica was tracking +2/3 stop.
The 67 was -1/3 stop off.
My test target was a medium beige interior wall which I varied the light on.
I am happy with 1/3 stop on everything.
I adjusted the Leica light meter before when changing from a Mercury battery and I might give it a touch up be I have never noticed a problem with exposure with it. I generally either shoot Portra 400 or Ektar 100 with the Leica so I will probably leave it alone.
I touched base with Eric and he said see what the first roll of film looks like, if OK keep shooting.
He said there was no lubricant in the camera to dry up.
I have a light seal kit coming and if the first roll is OK I guess I will just keep using it after replacing the seals.
Eric said he could to light seals and check timing if I wanted him too. Stand up guy.
---------- Post added 11-04-18 at 06:02 PM ----------
Originally posted by desertscape You got quite a deal in that kit considering that it looks new. It would have cost at least $3200 when it was produced. The Leicaflex SL was a good learning experience for using the 6x7 now. I have used the SL and SL2 quite a bit. They are spot metered but your 6x7 is not, so that must be considered when shooting. When you use the TTL meter, make sure you use a gray card as that meter is easily fooled by light or dark areas within the frame. Of your lenses, the only one that is not great is the 300 Takumar. It does not have a tripod mount but badly needed it. If you shoot it hand held, not a problem. BTW, the body serial number can be used to determine the age of your camera.
I have read that about the 300.
Have to figure out what the manual auto switch on the lenses does?
I have the original manuals for everything but didn't see a detailed explanation except it control the diaphragm?
The manual for the camera has about a 1/4" binder that doesn't look like it ever was open much less folded flat.
I would be shocked if it had a roll of film run through it.
I am super happy with this kit.
