Originally posted by rollsman4 I shoot in Raw. I am trying to get the monitor to get as close to the way the Image looks on LCD and My computer monitor
I use the Histogram
Not sure it's reasonable to expect a raw image viewed on your computer to resemble a JPEG viewed on your camera LCD, until after you have done some work in your image editor.
First, you are not really looking a RAW image on your computer monitor. Without any processing, a RAW file is a deep, dark, murky thing with barely any image details visible. That is, when viewed on your computer image software, the software has applied a set of default processing steps to make the raw image "look right" on your screen. It would be a coincidence if the default settings in your desktop software resulted in an image which looked just like the image the camera processing produces when generating the JPEG you see on the camera screen.
Depending on what image processing software you use on your computer, it may be possible to create a set of adjustments that will, more-or-less, recreate the look of the camera JPEG. Your image editor may let you save the steps needed to get your desired result as a preset, which could then be applied to all RAW files from that camera at import.
What image editing software are you using?
