12-03-2018, 04:10 PM   #31
johnha's Avatar
Old cameras come in kinds of conditions, I've only sent things off for CLA/Repair when they're broken or obviously in a bad way. Disassembling an old camera has risk associated with it (how the workshop deal with this risk is something to consider), personally I'm firmly of the belief not to medal with something that works.
12-03-2018, 08:22 PM   #32
Well, camera arrived today, and anticipation quickly turned into disappointment. KEH sent me a 6x7 instead of a 67... Second time buying from them, second time unlucky. Will give them a call tomorrow.
12-04-2018, 09:43 AM   #33
rjm007's Avatar
QuoteOriginally posted by Ediz7531 Quote
Bummer - shame it wasn't the other way round....
12-12-2018, 08:33 PM   #34
Got lucky and found one from Roberts Camera. It’s on its way to Eric as I type.
Question: it comes with a grid matte focusing screen with a center circle but without a fresnel or split. Presumably it’s either the BG-60 or BG-80. How can I tell the difference?
12-16-2018, 03:04 PM   #35
Congrats.
As you noted both the BG-60/80 have a grid but with no split or microprisms. The BG-60 is a standard screen and is compatible with all the 6x7 lenses. The BG-80 is a brighter screen and is especially suited for telephoto lenses. You can experience corner darkening with this matte and the following lenses: The 35, 45, 55, 75, 75 shift, 55-10mm zoom and 90-180mm zoom per the Pentax 67II Interchangable Focusing Screen operating manual.
The 67II interchangeable frame holding the matte has the model number on it. If the matte is taken out the the interchangeable frame to put into a 6x7/67, I don't know how you'd tell which one you have from looking at it. Perhaps if you can experience corner darkening with one of those noted lenses or not you'd know.
12-17-2018, 09:34 PM   #36
Congrats.
Thanks! I only briefly tested pointing and focusing with the 105mm lens on. I also bought the 75mm 4.5 lens. Will test using that lens when the camera comes back from Eric.
12-18-2018, 09:42 AM   #37
johnha's Avatar
IIRC replacing the screen is a service centre job, if you have a preference for a different one it might be an idea to see what Eric might be able to do?
12-18-2018, 09:45 AM   #38
QuoteOriginally posted by johnha Quote
Indeed, I asked Eric and he has spare standard focusing screens. I'll see if I can get used to the grid-matte.
12-18-2018, 09:46 AM   #39
I put a new matte in my 6x7. It's not hard. Just be careful not to drop any of the tiny shims and screws.
12-18-2018, 09:35 PM   #40
Silent Street's Avatar
That's the correct advice (from Pentax) and conventional wisdom would strongly suggest following that path (service centre).
You can do it yourself, but you will need patience to establish correct and accurate focus at 3 points in the centre (near and far, using a magnifier/loupe) and make adjustments with the screws and shims. Each tiny shim is matched to a specific position and sometimes a change is required when focus cannot be accurately achieved.
I am hunting for a grid / microprism screen. I have never wavered from that type of exceptionally useful screen during my very long use of 35mm (Canon EOS 1N and 1V). The lack of quick viewfinder horizontal and vertical reference is a constant threat of ending up with off-level horizons, what with the spirit levels of my Manfrotto Mg head being in front, which I makes it mightily irksome to see them in certain situations (such as a recent shoot when prickly lakeside reeds just below the lens threatened to impale my fingers and face!).
12-19-2018, 08:30 AM   #41
Actually on this note, is the standard focusing screen for the 67ii (BA-61?) brighter than the standard one for the 67?
12-19-2018, 09:39 AM   #42
On the 6x7/67, the focus screen is spring loaded in place. No adjustments are needed. The shims are to adjust the fit of the folding hood or Prism to the body so it isn't a loose fit.
12-19-2018, 11:58 AM - 1 Like   #43
According to the 67II sales manual, all 4 screens, including the BA-61 were multi coated to improve finder brightness over the older models,
01-04-2019, 10:35 AM   #44
So I got the camera back from Eric. I noticed that focusing at infinity is a little bit off with either of the two lenses I bought, so I hypothesized it's a problem with the screen.
Please pardon the stupid question, but does the screen being misaligned mean that whatever the screen shows as in focus won't necessarily be aligned with the image being in focus on the film plane?
01-04-2019, 10:48 AM - 1 Like   #45
Alex645's Avatar
IF the screen is misaligned then yes, but it could be the lenses as well. Before jumping to conclusions, I would run a test roll with both lenses at infinity and take good notes with shots using the lens on the infinity mark and at what your eye thru the finder appears to be infinity. Shoot with the apertures wide open. Also save a couple shots for a wall or focus chart test at 5 and 10 feet using the OVF for focusing.
645d, 645z, camera, hasselblad, medium format, pentax, pentax 67 vs, reliability, sub-forum, system, vs, vs hasselblad 500cm
K-5 vs MZ-S vs LX vs PZ-1p vs ist*D vs K10D vs K20D vs K-7 vs....... Steelski Pentax K-5 & K-5 II 2 06-28-2017 04:59 PM
Pentax 67 vs Hasselblad EL Femto1969 Pentax Medium Format 11 06-07-2017 08:20 PM
Hasselblad V Mount Modified Pentax 67's? NickStancato Pentax Medium Format 4 02-27-2017 11:30 PM
K-series vs M-series image quality-wise? Piotrek K Pentax SLR Lens Discussion 20 10-31-2016 06:22 AM
Good price for a Hasselblad 500cm system? abieleck Canon, Nikon, Sony, and Other Camera Brands 16 03-19-2013 09:49 AM
All times are GMT -7. The time now is 11:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
