Hello Stephan,
Subject Aperture ring:
I had set in my post above a link for an adapter that controls Pentax 645 lenses without aperture ring.
Https://www.fotodioxpro.com/collections/lens-mount-adapters/products/p645a-gfx-pro). The adapter captures the apature fork and controls the position via an aperture ring on the adapter. So you can take all Pentax 645 lenses without restrictions (except the two old Leaf Shutter lenses).
Subject Fuji G mount lenses quality:
I refer to all Pentax 645 lenses. The Fuji 120mm F4 Macro is sharper than the Pentax HD DFA 90mm. Look at the MTF charts at Fuji. (
http://www.fujifilm.com/products/digital_cameras/gfx/fujinon_lens_gf120mmf4_...specifications). The Fuji can also show 1: 1 on a fully electronic extension ring.
The Fuji 110mm F2 is also sharper with the aperture open than the Pentax HD DFA 90mm. And it has F2.
I have the DFA version of the Pentax 645 25mm F4. If I compare that with the Fuji 23mm F4, then the Pentax 25mm does not even come close to the 23mm Fuji.
The Pentax DA 28-45mm F4.5 is at a similar level to the Fuji GF 32-64mm F4. The Pentax 28-45mm is much more expensive, it has a smaller zoom range and it has more CA's.
The Fuji GF 250mm F4 with stabilizer is much better compared to the Pentax 200mm F4 or the Pentax 300mm F5.6. With the 1.4 tele converter the Fuji reaches 350mm F5.6.
But you also have to be fair and look at it from a purely technical point of view. When the Pentax lenses were designed the requirement
was not that they need to work on a 44x33mm sensor with 100 Mpix and a pixel pitch of 3.74 micron. The Fuji lenses had exactly this requirement from the beginning.
What I wrote does not mean that the Pentax lenses are bad - quite the contrary. Only the Fuji lenses are, in most cases, even better.
I hope this helps you further.
Greetings Gerd
