I was in the camera store today in hopes of buying a Pentax 645 to Nikon F adapter so I could use all my 645 and 67 lenses on my Nikon cameras (D700, F100, FM2n etc.).
Particularly,
KIPON Pentax 645 to Nikon adapter. Turns out
the adapter is poorly designed and doesn't work.
I was completely unable to attach the Pentax-A 55mm f/2.8 I took with me. The lens fits the adapter, but doesn't turn inside it. The 67 to 645 adapter fared better, but required noticeable turning effort. I tried both adapters the store had in stock and they were both the same.
Additionally, the prism box of Nikon F100 gets in the way so the adapter can't be mounted at all.
Nikon FM/FE is better in that regard, as the adapter just barely clears the front nameplate. Although, I'm not entirely sure it's not brushing against it and won't leave marks after some use.
I also tried the adapter with D800 they had in stock and it mounted without issues because D800 has more space around the lens mount.
Still, even if you have a camera that can accept KIPON Pentax 645 to Nikon adapter, it doesn't really matter because the adapter itself doesn't work.
I've attached photos of the adapter in case you wonder which one is it. It's not particularly easy to come by, but if you see one, don't buy it.
