12-12-2018, 07:37 PM   #1
Filter holder for S-M-C Takumar 6x7 400mm, Item #42901138?
I am looking for a rear lens filter holder for Pentax Super Multi Coated Takumar 6x7 1:4/400. Do you have any suggestions as to where I may search/look? Thank you in advance.
12-12-2018, 08:36 PM   #2
Docrwm's Avatar
KEH Camera or Roberts Camera.
12-13-2018, 08:47 AM - 1 Like   #3
gofour3's Avatar
QuoteOriginally posted by Ovickers Quote
I also have the 6x7 Takumar 400/4.
It uses 77mm screw in filters, or Pentax 6x7 77mm bayonet filters. Filters are attached to a removable adapter ring, which screws into the rear of the lens.
I'm assuming that you have double checked that the adapter is present? With no filter attached it's hard to spot, give the rear of the inside of the lens a light twist and see if anything turns.
When I got my 400/4 I though the adapter was missing, but it was actually in place.
If you are missing the adapter, the odds of finding one for sale are slim.
Phil.
12-13-2018, 08:57 AM - 1 Like   #4
Docrwm's Avatar
QuoteOriginally posted by gofour3 Quote
Phil.
Phil's the man!
12-14-2018, 10:05 AM   #5
These filter holders are so rare that finding one is not possible. Rear filters are problematic for this lens, as they introduce flare when using most filters. Polarizers are especially bad in this regard. Even using a multicoated polarizer does not fully solve the problem. After struggling with this for many years I finally opted for a front filter. Since the front is 108mm, there are no common filters that fit it. I use a 105mm filter that is mounted in a polycarbonate ring. The ring fits on the lens hood. No vignetting occurs.
customer inquiry, inquiry about item
Pentax Normal 40.5mm Filter (for rear filter holder of DA 560mm and 645 DA 25mm) angerdan Pentax SLR Lens Discussion 16 09-26-2019 04:30 AM
For Sale - Sold: Irix 15mm f/2.4 Blackstone with Irix 100mm filter holder and Light pollution filter valimyr Sold Items 3 10-26-2018 03:17 PM
Rear filter for smc Takumar 6x7 400mm/4 therion Pentax Medium Format 10 07-07-2013 02:25 PM
For Sale - Sold: Pentax 6x7 400mm f4 SMC Takumar & 6x7 to K mount adapter littledrawe Sold Items 8 04-30-2012 04:58 PM
Pentax 6x7 45mm: Vignetting using Cokin Z-Pro filter holder? leoyblam Pentax Medium Format 2 08-19-2010 08:04 PM
All times are GMT -7. The time now is 12:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
