01-04-2019, 01:58 AM   #1
67: 100mm macro f4 vs 105mm f2.4 & 165mm f2.8 vs 200mm f4
Hi all :-)
Does anyone prefer the 100mm over 105 as a normal lenses? If so, why? And do you miss the 2.8?
And for portraits - for those using the 200mm for this, are you missing the 2.8? I'd say I prefer the longer focal length, but I dont mind the 2.8 either :-)
Cheers
Peter
01-04-2019, 10:14 AM   #2
I prefer the 55-100 zoom @100mm over the 105 for landscape work due to its f/32 stop. The 100 macro also has f/32 so it would be OK too. Lens speed is not a consideration for my work.
01-04-2019, 12:33 PM   #3
gofour3's Avatar
I only use the 100/4 for macro work and mostly with the LSC, so the 105/2.4 is used for regular shooting along with the 90/2.8 & 75/2.8.
For portrait work the 200/4 is nice for head shots and the slower speed is not really an issue. You get enough isolation in a studio, due to the close focusing capabilities. (late version)
Phil..
01-05-2019, 01:19 PM   #4
My 2cents: i use the 135mm f/4 for macro; actually my very first 6x7 lens and 30+years old(?). Occasionally I add a helicoid extension ring for more! My 90mm, in leaf shutter or plain, are my norms. I use a few different choices for portraits including the 165mm LS lens - task specific. I rarely used my 200mm and sold it. I frequently opt for 6x6cm format for portraits, tho. I think your questions are good and need a priority assigned to each task. 75mm is a wide angle; 90mm-135mm is normal range; 150mm longer are telephoto range. What suits you today? Btw: I am not usually concerned with wide/fast aperture-low light not a usual concern. I use a suitable tripod frequently.
01-06-2019, 01:28 AM   #5
Thanks for getting back to me folks :-) It seems like the 200mm is a good option for me. And it also seems to me that the choice I have to make for normals isnt between the 105 and the 100, but the 105 and 90 ;-)
01-06-2019, 11:09 AM   #6
I have the 90LS and 105/2.4. 90 is lighter and of course the LS, 105 has that unique look.
As for portrait lenses, I have the 165/2.8 and 300/4. 165 and 200 aren't that far away when it comes to focal length, so the 300's another option, and it's f/4 like the 200 but longer, so that's that.
01-07-2019, 10:19 AM   #7
The 67 200/4 is an optical update over the 6x7 200/4 generation. A good lens but a bulky design. The front element is recessed so far that you practically have a built in lens hood until you put on a filter. The 165/2.8 is much more compact and a lens I'd rather carry around.
100mm, 200mm, 645d, 645z, camera, f4, medium format, vs
Vintage Pentax 100mm Macro F4 vs Modern Canon 100mm Macro F2.8 Digital Asylum Pentax SLR Lens Discussion 10 12-06-2017 05:47 AM
For Sale - Sold: Pentax 67 165mm f2.8 SMC with lens cap & Pentax 67 55mm f3.5 Super Multi-Coated Tak digitalandfilm Sold Items 0 06-12-2016 10:05 PM
Lens Tournament: D FA 100mm F2.8 Macro vs 67 165mm F4 LS Adam Pentax Forums Giveaways 5 11-05-2014 04:33 AM
Pentax 67 165mm vs. 165mm LS darekj Pentax Medium Format 7 08-24-2011 11:19 AM
All times are GMT -7. The time now is 06:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
