02-07-2019, 12:12 PM   #1
Newly purchased a 645 A 150/ 3,5 lens and does not focus
Just purchased it and tried to get image in focus. I turned the lens focus barrel all the way right and left and it does not focus . Blurry. Is it the lens? Is there any settings the camera that I have to do to use the MF lens? Thanks Dennis
I am using 645D
---------- Post added 02-07-19 at 02:43 PM ----------
I believe its the lens. I move the focus side to side and it seems to slip sometimes. I will return it Thank you
02-07-2019, 01:18 PM   #2
Hi Dennis, I think you're right - it's the lens. Without even turning on the 645D, you should be able to see the focus change in the viewfinder as you turn the focus ring. I don't believe there are any settings in the camera body that you need to adjust to allow the lens to manually focus properly. Good luck.
02-07-2019, 03:53 PM   #3
Thank you Jon
03-23-2019, 10:27 AM   #4
Pentax A 150 mm f/3.5 focusing issues.
The 645 A 150 mm f/3.5 is very solidly built. For the barrel not to move back and forth when the focusing ring is turned, it means the lens must have been heavily abused and must be in a terrible mechanical condition. 645 bodies don't have an AF/MF button, it's the AF lens prongs that activate the AF function on AF capable bodies (645N, N II, D and Z).
03-23-2019, 08:30 PM   #5
Thank you Dennis
645d, 645z, camera, focus, lens, medium format
Misc A Test Shot with my newly acquired K-7 body and SMC 55mm Tak., F/2 Lens. Tonytee Photo Critique 7 12-30-2019 01:27 PM
Owners of Pentax 55-300 and 150-450 - Are you still glad you bought the 150-450? Joyce Keay Pentax K-70 16 02-17-2018 05:55 PM
Jupiter 9 stiff focus despite newly greased helicoid callumross Pentax SLR Lens Discussion 23 08-04-2017 01:03 PM
Another newly purchased 16-50 DA* rant David&karen Pentax SLR Lens Discussion 47 09-19-2011 01:25 AM
Some part of my image does not appear on focus, How can i get it all in focus? rustynail925 Photographic Technique 11 09-08-2010 07:24 AM
All times are GMT -7. The time now is 11:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
