Originally posted by rollsman4 [...]
I have to see if the 67 lenses are any better than the 645 ones same size lens. I would have to add an adaptor to use the 67 to 645 which is ok. Any suggestions are appreciated. Thank you
If you are looking at the 67 system 75mm equivalent (all manual focus), it exists in three forms: the weighty and clunky 75mm shift, plain 75mm f4.5 (challenging to focus in low light or with a polariser) and the uber-stellar 75mm f2.8AL. No bull, the f.28AL will set you back a hefty amount (esp. if it is found MINT/NIB/NOS, with trap-door [to enable use of a POL you remove this so you can stick your digit up there and make adjustments...] petal hood), and from a professional user's perspective, it is a delight to use, if a little weighty (understandably for its glass): contrasty, indisputably sharp, precise, touch sensitive focus and spring-loaded aperture. It takes the common 67mm filters (if you do put a filter on it, go for B+W or HOYA's). Expect around $1600 to $2,000+ for this lens but do check out any offering in your own hands and with your own eyes -- there are profiteers about, esp. in Japan.
