I had a similar problem with my first rolls (also Fuji). I was loading the film 'start' pointer to the exact position of the arrows in the camera, this often required an extra, complete revolution of the wind-on crank. In practise I found if I left the start pointer a little short of the 120 arrow (at the end of one full wind-on) the problem disappeared. My frame spacing is not consistent, some frames are nearly touching but not overlapping.
In the field you can roughly tell if this happens by where the frame counter is when it stops moving after winding to the end of the backing paper. Mine stops about 'frame' 15 if everything is OK, if it stops earlier than this, it may mean the film had run out by the time the last shot(s) were taken.
