04-12-2019, 09:10 PM   #1
HELP Pentax 645 - Film advancement not working
Hi there,
I recently purchase a classic Pentax 645 which was description as functioning, however I loaded the film and pressed the shutter for the auto-winder to go to the first exposure but the motor keeps running. It doesn't unless I turn it off and take the film holder out. It seems the film isn't advancing on the film holder at all either, and I'm definitely putting it in correctly.
04-12-2019, 10:21 PM   #2
Alex645's Avatar
QuoteOriginally posted by tatsumi Quote
Hi there,
IF you are certain, as in 100% positive, that you are loading the film correctly, then there is definitely a problem with the electronics or there is a broken gear. I have had my share of "brain farts" in which I've loaded mine incorrectly thinking I did it correctly.
Again assuming that you are loading the film correctly, the only other thing that I can think that could try to reset things by taking the batteries out and even the CR1220 lithium battery (you'll need a small spanner wrench).
04-13-2019, 07:15 AM   #3
jumbleview's Avatar
Check batteries. Even if one of six is out of orders the camera may behave unpredictably.
04-13-2019, 05:51 PM   #4
go underneath the camera there is a memory battery 1220 a tiny little thing. you need to replace it, you need a lens spanner to get it out. Basically the camera has lost its memory. OR PULL THE BATTERY PACK OUT AND MANUALLY TRIGGER THE SHUTTER A FEW TIMES
04-14-2019, 03:22 PM   #5
johnha's Avatar
I'm puzzled, if the film is loaded correctly, the insert is inserted correctly and the motor runs continuously - then I'd expect the film to wind to the end (unless as suggested there's a broken gear somewhere). The fact it doesn't suggests there's a problem with the drive mechanism, the motor runs continuously as it hasn't detected it's advanced the film to the first frame (which it hasn't).
04-14-2019, 04:03 PM   #6
QuoteOriginally posted by johnha Quote
No the computer gets tricked that is why, happened to me. Nothing is broken,except he lost the film.
09-06-2019, 12:54 PM   #7
QuoteOriginally posted by niceshot Quote
Hi niceshot ,the same is happening to me , my camera won't stop winding and it transfers the film completely , did you ever find the problem ? Thanks in advance !!
09-06-2019, 04:48 PM - 2 Likes   #8
QuoteOriginally posted by Cowboy83 Quote
take out the the back and manually rewind and fire the shutter manually a few times then fire it by shutter the reload. Dont worry it happens and it is not a permanent.
09-06-2019, 07:30 PM   #9
I will try that !! Thanks again !!
09-10-2019, 08:05 PM   #10
mickey's Avatar
Did it work?
09-14-2019, 04:23 PM - 1 Like   #11
Good News !!!!
I found and fixed the problem with my camera .
There are 2 pins that detect when the film back is on the camera , the one on the top side was stuck in , i discover this after taking the right side plate from the camera off , all i had to do is scrape the pin with a tiny flat screw driver , after that i tried the film again and it work great !!
i hope this helps !! and thanks again for the help !!
08-27-2022, 09:57 AM   #12
Mint
Same thing happened to me lost it once in a lifetime photograph session don’t know if I can trust the camera anymore so I will back up with traditional methods,, my two 645’are in mint condition!
645, 645d, 645z, advancing, camera, film, film advancement, holder, issue, loading, medium format, pentax, pentax 645 film, winder, winding
Pentax 645 not working? kenyonp Troubleshooting and Beginner Help 2 07-19-2012 09:55 PM
HELP! HELP! K5 not working/back from CRIS psychdoc Pentax K-5 & K-5 II 118 10-19-2011 05:50 AM
K-r will not take photos, shutter button not working - HELP! seattledotcom Troubleshooting and Beginner Help 8 06-08-2011 04:19 PM
Mirror is stuck up, shutter not working (Pentax 645) ShootingTheWinds Pentax Medium Format 5 01-16-2011 08:42 PM
survey: batteries working/not working with the K-x noou Pentax DSLR Discussion 25 12-03-2009 02:43 PM
All times are GMT -7. The time now is 12:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
