Originally posted by ZombieArmy Could you expand on this a bit? What exactly is wrong with the old 6x7 cameras?
The very first generation 6x7 didn’t have mirror lock, and there were reports of bad clutches in the film advance allowing frames to overlap. The second generation had MLU added, and a more robust film transport, though I was still able to cause the advance on my 6x7 to go out of whack by shooting original T-Max film with it’s thicker estar base.
Back in the day, the Mamiya Owners Group filed a class action suit against Kodak because the film was thicker than the ISO standard allowed. Apparently it was causing problems for Mamiya 6x7 cameras as well.
I got the film advance adjusted, and switched to Ilford film and never looked back. Kodak, by the late 1980s was so far behind the curve in film technology that their stuff wasn’t worth using anyway.
As far as which format to choose, I started with medium format with a Bronica ETR-S. I was shooting a lot of weddings and the Bronica gave sufficient quality and five more shots per roll. What I didn’t like about it was that the film transport was ninety degrees off conventional (I believe the Pentax 645 is the same) which made printing the negatives on an enlarger a pain in the butt. Everything was sideways.
My Bronica suffered a major disaster during a shoot that was taking place on the roof of a ten or so story building. I was sitting on a false wall at the edge of the building and managed to knock the camera over the side while reaching for a cup of coffee. A ten story fall to a concrete pad is not good for the life of a camera.
I took advantage of the accident to switch systems to the Pentax 6x7, using the insurance money and my available discount with Pentax Canada to go from the ETR-S and it’s 75mm lens to the 6x7, 75, 105 and 135 mm lenses. Eventually I added the 45, 90 leaf, 165 leave, 200 and 300 mm lenses, as well as the bellows to my system.
The 6x7 never let me down on the job, the glass is excellent, and the cameras are tough.
I eventually moved to 4x5 for my landscape work, which turned out to be an excellent move. The downside of the 6x7 was depth of field. It was difficult to impossible to secure sufficient DOF on May occasions with that camera, while the 4x5 with it’s flexible body allowed for much greater control, and much deeper depth of field.
