07-07-2019, 10:26 AM   #1
HD Pentax-D FA 645 35mm F3.5 on manual cameras
The review for the HD Pentax-D FA 645 35mm F3.5 (over here HD Pentax-D FA 645 35mm F3.5 AL [IF] Reviews - 645 Wide-Angle Primes - Pentax Lens Reviews & Lens Database) says "The lens has an aperture ring which makes it fully backwards compatible with 645 film cameras."
I want to use this lens on a dumb adapter, so the statement (above) is promising. However, I'd appreciate confirmation that I could actually focus the lens on a dumb adapter. I know it has a manual focus ring, but contemporary focus-by-wire lenses often need power to focus. Some of the earlier autofocus lenses, perhaps like this one, had a mechanical clutch that allowed actual manual focus without power.
So, can this lens be used on a totally dumb mechanical adapter (no power, no contacts)?
Thanks in advance, Rob.
07-07-2019, 10:55 AM   #2
If it's DFA, that means it is compatible with the digital Pentax 645s as well as the film ones. The film ones only used screw-drive focusing, not focus-by-wire, so it will be able to be focused manually.
Edit: Actually, DFA might not mean that about the focus mechanism, but on the Ricoh site is says it is "Body AF", which means it is the screw-drive AF mechanism used on the film 645s, so it is not focus-by-wire.
http://www.ricoh-imaging.co.jp/english/products/lens/645/wide/hdpentax-dfa645-35/
And here it indicates that all D 645 lens can be focused manually:
http://www.ricoh-imaging.co.jp/english/products/lens/common/annotation-focus-645d.html
07-07-2019, 11:57 AM   #3
There are no 645 adapters with contacts to begin with- only ones with the aperture lever.
So, the only sacrifice that's made with a completely dumb adapter is a fully manual aperture diaphragm. You'll be able to focus the lens just fine.
No 645 lenses currently focus by wire.
07-07-2019, 12:34 PM   #4
Superb, thanks for the quick responses folks. That's precisely what I needed to know!
Rob
35mm, 645d, 645z, adapter, camera, f3.5, fa, focus, hd, lens, medium format, pentax-d, power
For Sale - Sold: DA and HD DA Primes: DA 50 1.8, DA XS 40mm, HD DA 35mm, DA 21mm, HD DA 15mm Amarony Sold Items 8 02-20-2019 06:21 AM
HD 20-40 or HD 21 & HD 35 macro BarryE Pentax SLR Lens Discussion 33 09-03-2017 06:05 AM
35mm F3.5 AL [IF] HD FA 645 Chromatic Aberrations pshersby Pentax Medium Format 13 09-15-2016 09:01 AM
For Sale - Sold: Pentax 645 NII, 35mm f3.5 A, 45-85mm f4.5 FA, 80-160mm f4.5 FA, 300mm f5.6 FA Kmtn Sold Items 2 04-08-2013 09:28 AM
All times are GMT -7. The time now is 02:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
